Latest: Johnonsmith
Overall: 7920
Visitors: 134
Total: 134
18: Manuals & Files Downloads
50: Your Account
77: Home
113: Home
132: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Lubing the regs :: Archived
Lubing the regs
ItsJustMe
PostPosted: Mon Jan 12, 2004 2:05 pm    Post subject: Lubing the regs
How do I go about doing this?
What lube or oil do I need?
Please go step by step, i'm a 'newbie' to lubing the gun.
TY!
ItsJustMe
PostPosted: Mon Jan 12, 2004 2:53 pm    Post subject:
ALSO, is there anything else i need to lube?
vincib
PostPosted: Mon Jan 12, 2004 3:17 pm    Post subject:
Call ICD,, let them talk you through it.
2k4 Viking
2k3BKO,J&J Edge Kit,14"CP,Lapco Bigshot,Sidewinder/McDev 300psi guage/Mitey Max,Vapor Valve/Mods/Vapor bolt
2k3 Choas Board,Zenitram ASA w/microrock
NKP82
PostPosted: Mon Jan 12, 2004 11:10 pm    Post subject:
You just need to lube the reg pistons<white plastic piece with O-ring on it> and the ram shaft<what the hammer is attached too>. Only use white lithoum grease, shocker lubercant, and other equivilent fine grade lithium grease. Dont need to do this often, maybe twice a year at most, no more then that.
>12" Freak Barrel System
>14" J&J Performance Ceramic
>Dye Stickies 3
>CCM Clamping Low-rise
>AKA Sidewinder
>MacDev Red Valve
>Evlution II w/ Z Board
Bko_monkey
PostPosted: Tue Jan 13, 2004 1:58 pm    Post subject:
Actually with stock regs to keep the gun working it's best you should probably lube it after every few cases of paint or so Very Happy
ItsJustMe
PostPosted: Thu Jan 15, 2004 3:24 pm    Post subject:
somebody plz tell me where and how to lube the stuff!
pAiNtBaLlEr06
PostPosted: Fri Jan 16, 2004 1:42 pm    Post subject:
Go to www.obdo.net and look at the the technical and FAQ sections on the webpage to learn how to do it, and what it looks like (the pictures may be a little off since he was using a Shocktech bushy doing it)
PostPosted: Fri Jan 16, 2004 2:04 pm    Post subject:
I would think ICD is busy enough with their current work load. Do them a favor and just use the forums like the rest of us, you can find the same knowlege.
My suggestion is to lube the regs after every day's worth of play. It doesnt take that long and will keep your regs working great and your gun consistant.
Take the marker apart and anything that has an o ring put some GREASE on it. It doesnt matter just grease all o rings and the Ram shaft after you clean it off. Thats about it, make sure there is no dirt in your body and take your valve out, clean it, dry it, lube it. Take the regulators apart, clean and lube all the o rings and pistons and lastly just wipe down your bolt if you have a stock bolt. You can rinse it out in water it won't warp or anything and grease shouldnt have any adverse affect on the bolt. Just that the ball detent holding the pin in may rust after time.
If it looks dirty give it a clean and a lube and it should be all better.
pAiNtBaLlEr06
PostPosted: Fri Jan 16, 2004 2:11 pm    Post subject:
if you're good to your bushy, it will be good to you.
NKP82
PostPosted: Fri Jan 16, 2004 7:58 pm    Post subject:
Opps, should have specified that the ram does not need to be lubed often unless you play where it gets really dirty. But yah, like pat said, lube the regs after a days worth of play.
>Dye Stickies 3
>AKA Sidewinder
>MacDev Red Valve
new balance 1530 saldi online
Last post by Johnonsmith in ICD Gear Forum on Sep 17, 2020 at 08:37:29
puma italia scarpe
Last post by Johnonsmith in PRP General Forum on Sep 17, 2020 at 08:27:24
onitsuka tiger chaussures
Last post by Johnonsmith in ICD Mech Markers on Sep 17, 2020 at 08:19:53
Huh?
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 06:33:40
Line SI Promaster
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:53:58
Classic Fox Sold On MCB
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:30:01
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 05:10:57
2K20's demo allows you to build by taking control
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:50:58
Madden NFL 20 Highlights Sports Sims Betting Explosion
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:50:24
RS3 is nonetheless a good runescape game though
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:49:34
