Visitors: 101
Total: 101
66: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › LPR Removal? :: Archived
LPR Removal?
PostPosted: Fri May 29, 2009 6:27 pm    Post subject: LPR Removal?
Ok, I know I'll sound like a dummy, but I need to ask how you remove the LPR. I'm trying to break this marker down to clean and relube etc. Also when I look down the ram chasm the object at the bottom is red. i'm wondering if this a stock part etc. Could no find a schematic breakdown on here.
PostPosted: Fri May 29, 2009 7:02 pm    Post subject: Re: LPR Removal?
Unscrew. That's all there is to it. Just don't lose the valve spring an poppet that typically come out after the LPR.
The object you are seeing that is red is a MacDev red Valve. To take the Red valve out you need to take your tray off and unscrew the valve locking nut. Then push the valve out from the back.
Look here for a break down:
www.icd-owners.com/htm...=23&pos=20
PostPosted: Fri May 29, 2009 7:21 pm    Post subject: Re: LPR Removal?
that was easy...just didn't want to jack something up.
PostPosted: Fri May 29, 2009 7:22 pm    Post subject: Re: LPR Removal?
is the red valve good?
veedoubleugee
PostPosted: Fri May 29, 2009 7:27 pm    Post subject: Re: LPR Removal?
its on par with the vapor valve...So yes its good.
PostPosted: Fri May 29, 2009 7:41 pm    Post subject: Re: LPR Removal?
i c....said the blind man
veedoubleugee
PostPosted: Fri May 29, 2009 9:06 pm    Post subject: Re: LPR Removal?
lol
PostPosted: Mon Jun 01, 2009 3:27 pm    Post subject: Re: LPR Removal?
Ok, so now I have the LPR off and the valve out. It is indeed a nice shiny red one. About the LPR...how do you disassemble it for annodizing?
PostPosted: Mon Jun 01, 2009 3:51 pm    Post subject: Re: LPR Removal?
unscrew it some more!
both ends will screw out.
PostPosted: Mon Jun 01, 2009 6:26 pm    Post subject: Re: LPR Removal?
thanks. that did the trick
