Latest: Fadomtg77
Overall: 7926
Visitors: 298
Total: 298
107: Home
128: Your Account
137: Home
138: Home
153: Home
165: Photo Gallery
168: Home
176: Your Account
184: Home
190: Photo Gallery
192: Photo Gallery
197: Photo Gallery
198: Photo Gallery
205: Photo Gallery
222: Photo Gallery
226: Your Account
246: News
259: Home
262: Forums
263: Forums
267: Forums
271: Forums
272: Forums
273: Forums
274: Photo Gallery
275: Forums
277: Forums
279: Forums
280: Forums
281: Forums
283: Forums
285: Forums
286: Forums
287: Forums
288: Forums
289: Forums
290: Forums
291: Forums
292: Forums
293: Forums
294: Forums
295: Forums
296: Forums
297: Forums
298: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › eclipse hpr adjuster :: Archived
Go to page Previous  1, 2, 3
PostPosted: Sun Aug 23, 2009 10:25 am    Post subject: Re: eclipse hpr adjuster
i know...random angelfire site i found when googleing "bushmaster lpr spring" Smile
PostPosted: Sun Aug 23, 2009 2:25 pm    Post subject: Re: eclipse hpr adjuster
That was Tanks old site, He used to be THE ICD guru. He was just leaving the scene when I showed up, and I have no idea what he's up to these days. His site is still there in pieces.
PostPosted: Sun Aug 23, 2009 8:31 pm    Post subject: Re: eclipse hpr adjuster
**(playing "it's a small world" song)**
It's a small small ICD world....:)
zinger565
PostPosted: Mon Aug 24, 2009 1:24 am    Post subject: Re: eclipse hpr adjuster
I was looking at the site...I had no clue that MacDev made their own Bushy...and I vaguely remember seeing a CheckIt Bushmaster once.
Holy hell did Eclipse make a bunch of parts for the bushy's back in the day!!
Class of 2009! Done!
DonF
PostPosted: Tue Sep 29, 2009 11:37 pm    Post subject: Re: eclipse hpr adjuster
I have a few of the Eclipse HPR knobs too- thought they were LPR! DUH! Oh well -On my splash ano xmill I have a matching ICD HP Regulator. I was just thinking about reviving the reg with a few changes, just to try.
Now The early spring does look smaller from the link but the piston is also different! Do the springs have to be matched to the piston? You cant very well just bore the adjuster out as the Eclipse knob narrows.
Check this out
www.angelfire.com/extr...s-regs.htm
Seems ICD upgraded the spring and the small spring has special requirements - (500 psi or less tank reg)!!
This came from the same site -
"The Gen5 Same as the Gen4 but with new regulators. The HPR has a bigger plunger and heavier duty spring designed to take a preset tank (800psi). The LPR has also been made shorter internally to allow for more air storage and faster recharge rates."
So it looks like the eclipse adjuster will actually down grade the regulator if the small spring and piston are used. Will have to look at boring it - if not feasable then its all pretty much garbage.
PostPosted: Wed Sep 30, 2009 12:43 pm    Post subject: Re: eclipse hpr adjuster
yeah, i thought about boring out the Eclipse HPR but I felt like the walls would be so thin that it looked shaky to me. Also the eclipse adjuster has not nearly the depth that the ICD one has so the adjuster would not screw in far enough to make use of the set screws to lock in the adjuster....i don't know maybe it would but this from memory as I'm at the office right now.
I used the stock HPR internals for a post 2700 SN# marker and just swapped in the LPR spring and it is regulating fine using a crossfire low pressure tank. Recharge rate seems fine on semi auto as fast as I can shoot.
DonF
PostPosted: Thu Oct 01, 2009 3:08 pm    Post subject: Re: eclipse hpr adjuster
I measured the knob to bore for the big spring- it wont work.
I dont want to mess with a LP tank I have two macdev tanks set at 650 and an old reg isnt worth changing for. So I have two new eclipse HPR knobs that I will never use.
PostPosted: Thu Oct 01, 2009 4:08 pm    Post subject: Re: eclipse hpr adjuster
I don't blame you.
The only reason I would even want to use the Eclipse adjuster is to get rid of that long foregrip. I mean you can just take it off but the stock adjuster threads show and leave things looking unfinished. Probably wouldn't take much to make a screw on collar that resembles the Eclipse without messing with the internals of the reg. I'm just thinking out loud here...again not much benifit to doing that either.
DonF
PostPosted: Thu Oct 01, 2009 4:16 pm    Post subject: Re: eclipse hpr adjuster
It would be worth messing with if the regulator was a great one, I though I might regrove the piston for two orings and add the adjuster knob to make it better but the early ICD regs arent that great so I'm just keeping the black Cp instead of the multi colored ICD. It hit the garbage cat this morning in fact Smile I have used the later FS regs on my B2ks without sacrificing too much consistency. If they had bottom inlets I would use them more but the line going up the reg is such a PITA grip wise.
PostPosted: Thu Oct 01, 2009 4:53 pm    Post subject: Re: eclipse hpr adjuster
so true...
Page 3 of 3
Skechers Flex Appeal a few
Last post by Fadomtg77 in ICD Mech Markers on Nov 30, 2020 at 05:43:04
Nike VaporMax 360 posiblemente
Last post by Fadomtg77 in Paintball talk on Nov 30, 2020 at 05:39:11
adidas tubular x soldes
Last post by Fadomtg77 in Off Topic on Nov 30, 2020 at 05:34:17
puma suede femme noir
Last post by Fadomtg77 in Calendar of Events on Nov 30, 2020 at 05:30:04
Mike Tomlin implies there is a trong possibilitythe Steelers
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:45:00
Packers stay on offense, add RB A.J. Dillon
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:39
For 2nd straight season, Seahawks offense struggling to fly
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:12
Chiefs welcome fresh/outdated faces inside of Allen
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:58
Run defense issues highlight total breakdown for Saints
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:15
Pitch and catch: Round 2 of NFL draft heavy on receivers
Last post by Osweiler in Off Topic on Nov 26, 2020 at 03:42:37
