Visitors: 72
Total: 72
63: Surveys
Forums › General › Paintball talk :: Archives › my nipple leaks!! :: Archived
my nipple leaks!!
PostPosted: Thu Jan 28, 2010 5:21 am    Post subject: my nipple leaks!!
on my dye tank, one of the nipples leaks massively after the nipple is disconnected from the gas line. when i take it apart, the oring is not reseting; infact, the oring is unseated on one side and the little cylinder thingy is prevented from being pushed up into place. i tried lubing it with some shocker grease, but no improvement.
any ideas or should i just replace my leaky nipple?
edit: here is a picture. it looks like the sudden influx of air going into the tank pushes the oring out of place?
PostPosted: Thu Jan 28, 2010 10:18 am    Post subject: Re: my nipple leaks!!
I would not have greased it at all. Grease and oil are big "no-nos" for HPA tanks. If that grease or oil gets in the tank it could cause a big caboom. Shocker grease should be dow 33 which is silicone based but I still wouldn't risk it.
Just go to your shop and get a new one.
PostPosted: Thu Jan 28, 2010 12:02 pm    Post subject: Re: my nipple leaks!!
NOOOOOOOOOOOOOOOOO!!!!!!...dont ever again put that nipple in a tank!
putting oil or grease onto a fill nipple actually turns your tank into a bomb(mike from techpb actually had a very serious show on this)
bottom line...get your tank inspected to make sure NO grease got into it and if thats fine then get a new fill nipple (cp nipples are great for the price) and you can just chuck that nipple out
PostPosted: Thu Jan 28, 2010 12:46 pm    Post subject: Re: my nipple leaks!!
new nips FTW!!
PostPosted: Thu Jan 28, 2010 2:21 pm    Post subject: Re: my nipple leaks!!
Next stop for this tank is ninja reg swap anyways. 40 bucks for a hydro and a new reg? Great deal.
PostPosted: Thu Jan 28, 2010 2:27 pm    Post subject: Re: my nipple leaks!!
Do they give a time frame for my explosion? It did this with the last nipple, and that was the one I greased the piston on to no avail. I had this one at home, and I changed it out and it worked fine for a while. But last time I played...I didn't even mess with it when it started back up.
PostPosted: Thu Jan 28, 2010 3:09 pm    Post subject: Re: my nipple leaks!!
if you suddenly stop posting we'll know what happened... Smile
PostPosted: Thu Jan 28, 2010 5:36 pm    Post subject: Re: my nipple leaks!!
I don't think that it is a garunteed explosion but it is one of those things that can happen.
Oh and I agree, if you aren't around for a while we'll know why and post up a memorial.
PostPosted: Thu Jan 28, 2010 6:13 pm    Post subject: Re: my nipple leaks!!
^^^we'll set up a paypal memorial fund and we'll make sure your markers go to good homes. lol
Tzarector
PostPosted: Thu Jan 28, 2010 6:52 pm    Post subject: Re: my nipple leaks!!
brutal
