Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Vapor bushy wont chrono over 230... HELP :: Archived |
Vapor bushy wont chrono over 230... HELP Have a problem with your marker? Ask here
View previous topic :: View next topic |
Author |
Message |
xi9 Rookie
Joined: Nov 06, 2003 Posts: 21 Location: Clarkston, Mi
Posted: Mon Feb 02, 2004 9:28 pm Post subject: Vapor bushy wont chrono over 230... HELP |
I have no clue what the problem here is BUT I cannot get my bushy to shoot over 230 fps right now. Everyone is boggled by this, maybe someone here could help. I recently purchased vapor valve, FMD Hosed with palmer rock, polished ram assembly and a vapor bolt from a local shop that parted out a vapor bushy for me. Im running the stock 2K3 PDS board. How i adjust my lpr is i tighten it untill my noid leaks then back it out a turn or more. My hpr i START at just below 120psi the rase it over the chrono to try and get my desired FPS. I have pushed my HPR all the way just below 300 psi. Im running the stock inline  and a Center Flag LP Tank. Ive tried putting on a BRAND NEW palmer rock and a NEW WGP ORRACLE TICKLER REG to see if it was my lpr and it wasnt. And i tried a AKA Sidewinder in replacement for my stock inline reg... nothing i have tried has worked. and yes i have a new battery in the gun and i use a cp kit so i know im getting a good paint-barrel match. LOL PLEASE HELP!!!!
Back to top |
chord509 Novice
Posted: Tue Feb 03, 2004 8:33 am Post subject: |
What are your dwell settings? Try incresing the dwell and see if your FPS changes.
"Then Jesus said, ‘Father, forgive them; for they do not know what they are doing.’" -Luke 23:34
CPPA Member #1485 |
Back to top |
PatrickLee Pleeairsmith.com
Joined: Sep 23, 2003 Posts: 1291 Location: Long Island/Queens
Posted: Tue Feb 03, 2004 8:48 am Post subject: |
he cant change dwell, he is using a stock 2k3 board.
Try starting off at 200 PSI and then play with your LPR. Instead of making the noid leak turn the LPR up till your gun fully cycles at a high ROF. Then adjust FPS via the HPR.
_________________ NYC REVOLUTION |
Back to top |
xi9 Rookie
Posted: Tue Feb 03, 2004 7:07 pm Post subject: |
doesnt matter anymore... all the vapor **** is gone, im back to stock and im probly going to get a trix.
Back to top |
chord509 Novice
Posted: Tue Feb 03, 2004 10:38 pm Post subject: |
That's weird. I was able to adjust dwell with my 2K2.
CPPA Member #1485 |
Back to top |
pAiNtBaLlEr06 Novice
Posted: Thu Feb 05, 2004 2:13 pm Post subject: |
the 2k3 board does not have dwell settings, the 2k2 and maybe the early early 2k3's had dwell settings
Back to top |
Nynexx Borg shooter - Resistance is futile!
Joined: Jan 20, 2004 Posts: 174 Location: Hamilton,Ontario,Canada
Posted: Thu Feb 05, 2004 2:52 pm Post subject: |
i got sort of the same problem but I can't 250fps.. with out having to take out the spring?
Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
