Latest: Tjone
Overall: 7904
Visitors: 148
Total: 148
94: Your Account
Forums › General › Paintball talk › Hater Sauce Lube?
Hater Sauce Lube?
Mikeraps
PostPosted: Sat Jun 23, 2012 12:07 am    Post subject: Hater Sauce Lube?
Hey Guys,
I've read a bunch of your threads on useful lubes for ICD guns (particularly Bushy, Promaster and FS5). In them I see references to Dow 33,55 and Super Lube. However, no reference to Hater Sauce. Is this considered a good lube for ICD markers or would people advise against it?
Thinking of going to the hardware store and buying some Dow and Super Lube if the Hater Sauce doesnt cut it. Thanks
You only live once
PostPosted: Sat Jun 23, 2012 12:21 am    Post subject: Re: Hater Sauce Lube?
I don't know for sure, but it looks like a dow 33 based lubricant.
Someone else will have to chime in, but you could probably use it on rams and regulators. You can use it in FS bolt assemblies, but it will do the same thing dow 33 does (ie decrease the performance).
Mikeraps
PostPosted: Sat Jun 23, 2012 12:55 am    Post subject: Re: Hater Sauce Lube?
Thanks for the quick response.
So sounds like i shouldnt use it on any of the Cylinder Assembly both the FS5 and Bushmaster and should buy some lithium grease for that?
You only live once
lexiones
PostPosted: Sat Jun 23, 2012 1:07 am    Post subject: Re: Hater Sauce Lube?
Dow 33 and gold cup have gotten any gun I've ever had running very well. Sometimes if I'm looking for a thinner lube for a spool I will thin out Dow33 with goldcup.
There is one exception to this and that is Motion Potion in DM3/Gen-E matrixes.
Call me a ludite but I have not had an issue with any of the several hundred gun I have owned using those 3 lubes. In addition to the several thousand that I have teched.
PostPosted: Sat Jun 23, 2012 2:09 am    Post subject: Re: Hater Sauce Lube?
For the bolt assembly of the FS5, oil is a must. Grease will creates drag and you will have too increase your HPR and LPR pressures to achieve the same FPS.
PostPosted: Sat Jun 23, 2012 2:10 am    Post subject: Re: Hater Sauce Lube?
lexiones wrote:
Call me a ludite
You get ten points for using that word.
PostPosted: Sat Jun 23, 2012 3:18 am    Post subject: Re: Hater Sauce Lube?
i've never been a fan of gold cup. then again, i use KC Troublefree for anything oil related. i've had the same oil for over 10 years, cause a little goes a long way.
PostPosted: Sat Jun 23, 2012 2:33 pm    Post subject: Re: Hater Sauce Lube?
I am a huge fan of Lurker lube right now. It's like the best quality Dow I have every used.
But for Op's question, I use Dow33 or 55 on the ram orings, dow 55 on the valve orings, and thats a bout it. Bushy's don't need a ton of lube.
When I had a FS I was using superlube, which is what everyone recommends.
PostPosted: Sat Jun 23, 2012 2:37 pm    Post subject: Re: Hater Sauce Lube?
Don't use dow 55 on anything in a freestyle. It swells orings.
PostPosted: Sat Jun 23, 2012 2:40 pm    Post subject: Re: Hater Sauce Lube?
Sorry, should have clarified better. I meant the little tubes of lubey greasy oil that you get a radio shack. I thought it was called superlube?
Wtb Indian creek design solenoid 982030
Last post by Tjone in ICD Gear Forum on May 30, 2018 at 21:33:32
Last post by lasoyapro in Paintball talk on May 25, 2018 at 18:38:48
Last post by Walkertl in ICD Mech Markers on May 15, 2018 at 19:06:39
Last post by 63VDub in ICD Gear Forum on May 02, 2018 at 17:01:55
Last post by Tzarector in ICD Gear Forum on Mar 30, 2018 at 04:05:35
Last post by Un2XS in PRP General Forum on Mar 25, 2018 at 21:32:43
WTB: Promaster
Last post by ViperXT in ICD Gear Forum on Mar 23, 2018 at 16:16:25
