Latest: major_movit
Overall: 7915
Visitors: 201
Total: 201
21: Home
59: Your Account
93: Home
120: Your Account
176: Photo Gallery
179: Home
180: Home
184: Photo Gallery
187: Photo Gallery
196: Photo Gallery
199: Photo Gallery
200: Home
Forums › Marker Talk › Problem/Tech forum › NIB bko problems out of the box
Word?
PostPosted: Mon Dec 17, 2012 4:33 am    Post subject: NIB bko problems out of the box
So,
I found a never bought 04 bko handed down from a closed paintball store, to one that's in business. Bought it for $50 and got it home aired it up, and it shot for a good while but then it just stopped. I looked up some other troubleshooting threads and tried the basics, so here's where I'm at
Solenoid clicks
Solenoid leaks when I crank the pressure
Ripped the solenoid apart and reassembled
still acts the same
New noid? Or potential ram issue?
PostPosted: Mon Dec 17, 2012 5:33 am    Post subject: Re: NIB bko problems out of the box
Have you lubed the HPR and LPR. The ram might be stuck too. After sitting for so long, some of the lube may have gummed up.
PostPosted: Mon Dec 17, 2012 6:13 am    Post subject: Re: NIB bko problems out of the box
try a new battery first.
I'd definitely apply new lube though as well
Word?
PostPosted: Mon Dec 17, 2012 4:55 pm    Post subject: Re: NIB bko problems out of the box
There was no battery in the gun, so I started out with a fresh one.
The hpr is a brand new sidewinder I've had sitting around and I haven't checked out the lpr. I'll try re lubing everything today and see if that helps.
homerj
PostPosted: Mon Dec 17, 2012 5:02 pm    Post subject: Re: NIB bko problems out of the box
You say the solenoid leaks when you crank up the pressure. What are you running on the hpr? The solenoid is supposed to vent when it's over pressurized. I used to run my bko around 210 & then chrono with the lpr. That always worked good for me. Without it aired up can you move the bolt & ram with your hand?
Word?
PostPosted: Mon Dec 17, 2012 8:17 pm    Post subject: Re: NIB bko problems out of the box
At 300+ it started to leak, I had it cycling at 150ish but currently it's set at 200.
And yeah the bolt and ram move freely when it's got air. The only odd thing is when I push the bolt backwards past it's at rest position it gets stuck on the end of the upper body tube.
PostPosted: Mon Dec 17, 2012 8:36 pm    Post subject: Re: NIB bko problems out of the box
300 is way too high, 150-200 is more int he range you'll be needing to operate at.
homerj
PostPosted: Mon Dec 17, 2012 8:47 pm    Post subject: Re: NIB bko problems out of the box
Yeah 300 is way high. Is it the bolt pin getting hung in the slot? Could be a milling mistake from the factory if that's the case.
Word?
PostPosted: Tue Dec 18, 2012 10:02 pm    Post subject: Re: NIB bko problems out of the box
No guys, you're killing me.
300+psi made the solenoid leak, it's set at 200.
homerj
PostPosted: Tue Dec 18, 2012 10:40 pm    Post subject: Re: NIB bko problems out of the box
Ok, so with it set at 200 it no longer leaks but still won't cycle?
