Menu: |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum › 2k bushmaster and 2k4 bko troubleshooting |
2k bushmaster and 2k4 bko troubleshooting Have a problem with your marker? Ask here
View previous topic :: View next topic |
Author |
Message |
robinhood1143 Newbie
Posted: Mon Dec 01, 2014 2:54 pm Post subject: 2k bushmaster and 2k4 bko troubleshooting |
Ok, bushmaster first. At first, I pull the trigger and it fires, then I release the trigger and it fires again. Then, I pull it a second time and it DOESN'T fire, but when I release it the second time (and every subsequent time), it fires. I'm guessing electronics or wiring, but wanted to have a small idea before I take the thing apart.
Second is the Bko (std). When I gas it up, the bolt doesn't slide back to allow a ball to drop into the chamber. The hpr displays 225 psi. The electronics sound fine (it blinks when I pull the trigger), which is better than the bushmaster above.
Thank you so much for checking this and any help you can give.
Back to top |
Martix_agent ICDO Supporter
Joined: Dec 22, 2005 Posts: 3280 Location: Lafayette Indiana
Posted: Mon Dec 01, 2014 3:13 pm Post subject: Re: 2k bushmaster and 2k4 bko troubleshooting |
On your BKO, it sounds like your LPr isn't working properly, or that it is not set to a high enough PSI
the Bushmaster sounds like it has an electrical issue. I would check the wiring connections and make sure that the switch is wired properly.
Feedback |
Back to top |
homerj Pro Baller
Posted: Mon Dec 01, 2014 4:14 pm Post subject: Re: 2k bushmaster and 2k4 bko troubleshooting |
I believe the bko (being a fasor) used a spring to hold the bolt/ram back, not lpr air. It's been a long time since I took one apart so I forget how exactly the spring is in there but that's where I'd start.
Back to top |
Nobody ICDO Supporter
Joined: Oct 18, 2006 Posts: 5884 Location: New Jersey
Posted: Mon Dec 01, 2014 4:28 pm Post subject: Re: 2k bushmaster and 2k4 bko troubleshooting |
For the BKO, its Forward Air Spring On Return (FASOR). So, if the bolt is not moving upon airing it up, its the LPR. Take it apart, and relube it. Then set the pressure accordingly.
For the Bushmaster, it's either something in the wiring, i doubt it was wired wrong, but the microswitch might be giving out(being worn out) or broken so that you are only activating it on the initial pull but not any others. Turn it on without air, see if the LED blinks with each trigger pull.
If it's not a electronic problem, then reset the LPR. It could be too low and not resetting the ram back.
_________________ Furious Harnesses for sale
Crash1976 wrote: |
if it was an LCD I was going to make a VooDoo doll of you and stab the 5h!t out of you for swapping boards... but no LCD, so swap away. Cuz you were gonna be all rolling on the floor n' scream'n n' 5h!t... you wer're gonna be like "ah gods!...what have I done!!" and I was gonna be like "take that you eclipse bastardizing piece of fecal matter!" |
Back to top |
Posted: Mon Dec 01, 2014 6:02 pm Post subject: Re: 2k bushmaster and 2k4 bko troubleshooting |
Thank you, I'll look at the LPR in both cases.
Back to top |
Posted: Tue Dec 02, 2014 2:05 pm Post subject: Re: 2k bushmaster and 2k4 bko troubleshooting |
UPDATE!
Ok, I adjusted the lpr on the BKO until I heard it start leaking. That did the trick in pushing the bolt back, BUT, I couldn't get the it to stop hissing/leaking without sufficient pressure on the bolt to push it back. Most likely lube and o-rings. easy cheesy.
The bushmaster is most likely electronics. I turned it on without air and the same trigger pull problem. I'll tackle that after the bko.
THANK YOU, so much, for all your help, everyone! It was so awesome to see not only one but 3(!!!) replies so quickly.
Back to top |
Posted: Tue Dec 02, 2014 6:00 pm Post subject: Re: 2k bushmaster and 2k4 bko troubleshooting |
If you can't figure it out, you can send it to me. I am better at B2Ks as i have never had any experience with BKOs.
As for the hissing, you want to set the LPR pressure. Zero it out, then increase till the bolt moves back, then a quarter turn more should get you were it will shoot but not hiss(the hissing is too high pressure for the noid).
Crash1976 wrote: |
Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
