Visitors: 79
Total: 79
07: Home
09: Your Account
77: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › B2k3 GAS HOG :: Archived
B2k3 GAS HOG
calmiller
PostPosted: Sat Jul 10, 2004 11:49 am    Post subject: B2k3 GAS HOG
I have a b2k3 w/ and 04 reg, red valve, freestyle board, and shocktech bolt and I am getting 600 shots AT BEST off w/ a 68/45. I bought the gun used, HPR set at 200 and LPR is set 1 turn until it cannot recock. When I am sometime shooting fast i hear a PSST coming from around the LPR area. I just don't know what the problem could be. I tried taking the inline apart but the very top part wont come out, the other 2 come off fine tho. Is there a b2k4 regulator breakdown anywhere and a detailed desription on where to lube? Thanks alot.
Leterrip
PostPosted: Sat Jul 10, 2004 3:04 pm    Post subject:
you will get very bad efficiency if you have leaks. you should probably take the LPR apart clean and lube that.
John2
PostPosted: Sat Jul 10, 2004 3:09 pm    Post subject:
Yes there's a breakdown:
obdo.flipty.com/tech-b...sembly.htm
Have fun cleaning and lubing Smile
calmiller
PostPosted: Sun Jul 11, 2004 11:44 am    Post subject:
are the bko regs and bushy regs the same/similair? Cuz im not seeing a ball bearing anywhere in my reg. The reg is the stock 04 reg. Also, i can't get the piston out of the main section.
RaGeN_aZn
PostPosted: Tue Jul 13, 2004 11:37 am    Post subject:
ummm u should get a new aftermarket HPR...some stock HPR's will not have very high recharge rate
PBN feedback> www.pbnation.com/showt...287002#pos
chomponthisr3
PostPosted: Thu Jul 15, 2004 8:00 pm    Post subject:
yeah very true, but 04 reg should be fine. i think it might be the 04 reg and the freestyle board for 1 reason. the dwell might be set too high and the lpr might be set too low making efficiency terrible
chomponthisr3
oh yeah maybe from the shock tech bolt there is blow back (kinda of a leak)
bobsbarricades
PostPosted: Thu Aug 12, 2004 7:37 am    Post subject:
the shocktech bolt is supposed to be a blowback solver and a really good bolt from what I hear. you've got the ups so just clean the regs. might as well take apart the whole gun just to make sure there isn't some other problem
Big_Mac
PostPosted: Sat Aug 14, 2004 5:59 am    Post subject:
unless you have major breech scratching or a screwed up bolt I don't think it's the ST bolt. Find the source of that leak and fix it, then check the dwell. Excessive dwell is a real gas hog.
Stupidity Kills
levi333
PostPosted: Sat Aug 14, 2004 11:47 am    Post subject:
The ST bolt is NOT a blowback solver. But i doubt thats the prob anyway. You more than likely have a leak or two.
Silver BKO3ยด
-CP Reg -12" Silver/Black CP 2pc -Silver Zenitram 45 Magnetic Frame -DYE Carbon Fiber Grips -OTB Blind Bolt -CIP Clamping Rise -AKA Mitey Max -Vapor Valve -Kapp Gauge -WGP Torpedo Drop
View user's profile Send e-mail MSN Messenger
