Visitors: 86
Total: 86
26: Your Account
62: ICDO Chat
81: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › leaking?! :: Archived
leaking?!
bushyman06
PostPosted: Mon Jun 20, 2005 10:49 am    Post subject: leaking?!
ok, my bushmaster was leaking from the noid last time i played(biiig leak), so when i changed my frame, i tightened all the screws and checked/lubed the gaskets on it. i put about 1k of air on it last night to see if it leaks, and it doesn't. so i think i fixed it.
after about 10 minutes i noticed the bolt was only half cocked now, so i turn up lpr til it cocks all the way and i listen for a leak and i cant hear anything, so i think i fixed it again.
i didnt check it this morning but i just got home for lunch from work, and i noticed the bolt isnt cocked anymore, and all 1kpsi is gone.
i couldnt hear a leak so im confused...also, the 2 back tray screws are stripped out(meaning no screws back there), and when i put the gun down last night, i guess the tray moved a little, and it started to leak like crazy again so i moved the tray a little, and it stopped.
just wondering where the leak is from, and why it leaks when the tray moves?
OHS_Pyro89
PostPosted: Mon Jun 20, 2005 3:04 pm    Post subject:
When you move the tray you might be pushing the releif valve on the noid wich then leaks all over the place im guessing. Or its just pushing the noid of the gasket and it leaks a little. You might wanna get those retapped itll help alot.
bushyman06
PostPosted: Mon Jun 20, 2005 4:18 pm    Post subject:
k, ill retap it and let you know if it keeps leaking.
any clue on the silent leak?
TheItalian
PostPosted: Mon Jun 20, 2005 6:59 pm    Post subject:
My tank also leaks a little when it is unplugged, leave it for a few weeks or a month and I'll lose some psi. I guess it is sped up when you leave your marker gassed up.
View user's profile Send e-mail Visit poster's website AIM Address MSN Messenger Yahoo Messenger
bushyman06
PostPosted: Mon Jun 20, 2005 7:07 pm    Post subject:
but it was not even 24hours...?
TheArtist
PostPosted: Tue Jun 21, 2005 8:31 am    Post subject:
It's not a good idea to leave your marker gassed up for extended period of time. I even degass between games if they are 20 minutes apart.
Painting kids is just a hobby<br />urbanwarfare1.com
bushyman06
PostPosted: Tue Jun 21, 2005 9:08 am    Post subject:
i would, but my damn on/off is so hard to turn.:(
bushyman06
PostPosted: Mon Jun 27, 2005 8:20 pm    Post subject:
ok, i fixed all the other stuff.
now whenever i air up the marker, it sounds like its leaking through the feedneck. i know the feedneck can't leak, but thats where i can hear the air the most. any ideas?
bushyman06
PostPosted: Tue Jun 28, 2005 5:17 pm    Post subject:
okay, im pretty sure the leaking is because of a ram oring..
i checked the 3 on the ram housing, which other one could it be?
PureHybrid
PostPosted: Tue Jun 28, 2005 5:40 pm    Post subject:
if its in the feedneck it may be the seal on the pin and valve.
B2K4(red fade), CHAOS, CP reg, stainless FrEaKiT, Vapor Valve, Modded ram, Customclamp feedneck, Nitroduck 90/45, bunch of little stuff that dosent matter.
