Latest: Tjone
Overall: 7904
Visitors: 93
Total: 93
25: Your Account
31: Your Account
45: Your Account
Forums › Buy/Sell/Trade › ICD Gear Forum :: Archives › EvilPipeKit-ZFrame-Board....ALL SOLD..... :: Archived
Go to page 1, 2, 3, 4, 5  Next
adammiddagh
PostPosted: Tue Jan 10, 2006 12:18 am    Post subject: EvilPipeKit-ZFrame-Board....ALL SOLD.....
I accept PayPal only, shipping is USPS Priority Mail and is included with insurance and delivery confirmation. Everything is sold as is, ask questions before buying, use my email. I will try to repressent everything as accuratly as possible. If I do not feel the item is in working condition or better, I will not list it. Feel free to negotiate, it may not get you anywhere, but I will respond. Continental United States only, if outside US please email me for a shipping quote.
Original image:
img72.imageshack.us/im...1po9wp.jpg
Everything is sold on these images:
img67.imageshack.us/im...out2bm.jpg
img7.imageshack.us/img...out7vc.jpg
If you require better pictures, email me what you want to see and I will shoot it.
For Sale:
5. Modified ram, plee air smith ram mod, highly polished, small scratches visible on shaft, does not leak, hammer was lightened too far, then threaded and had a nut put on it to add most of the weight back. Price: Traded for reballs.
6. Home made ram gauge, see bushmaster forum for better pics. Price: Included with ram.Gone
12. Stock b2k4 board, cut bottom portion off, works fine. Price:SOLD
17. Zenitram Z frame, magnetic trigger mod, the original owner milled out some of the inside to make room for a 9v, and some on the inside of the grips, push pins included. The inside of the grip has some paint left on it, but the outside has been stripped down to the anodizing. Price:SOLD
23. Full Evil Pipe kit, tip to make 16 inch barrel, all 5 backs, cocker thread. Price:SOLD
Sold
1. Modified Stock LPR, Ported and polished. Probably one of the most consistant stock lprs anyone has put together, slightly higher flow than stock. Price: $16 Sold to Joe S, included pull pin.
2. My custom body, look in the bushmaster forum for more pics and details. Eye covers, eye holders(3mm), and neoprene washer detents are going with the body. Price: $45 Sold to Jesse, combo deal
3. Lightened stock pull pin, it is drilled in from each end to reduce weight. Price: $7 included free with lpr to Joe S.
4. Alamo City bolt, 2 orings, beware, the front oring tends to cut itself up during operation. Price: $15 Sold to bushball, included stock bolt and spare orings.
7. Stock asa with bolt, oring, and 0-300 psi gauge. Price: $13 Sold to Chuck G along with DOP Drop for $23
8. Ebay high flow valve, does not leak. Price: $13, includes stock valve listed below. Sold to Chuck G.
9. Stock valve with spare seal, I do not remember it leaking, It is also modified to be slightly higher flowing, it dropped about 25psi off of the stock milling. Price: Included with ebay valve.
10. Stock Noid and manifold, no leaks, it works, but I would consider it for spare parts. Good coil, I question whether or not the internals are openning fully. It works, but I question it, this is sold as is. Price: $18 Sold to Acid Custom
11. Stock wiring harness, 25gr switch, bright led installed, factory led included, pds works fine, has disconnects, screws included with switches, spare eyes included. Works just fine. The installed eyes have a couple of pinches in the wires, but like I said, it works fine. Price: $25 Sold to Jesse, combo deal
13. 2k4 Chaos board, Max Mode programming, tourney lock jumper included. Price: $35 Sold to Holygoalie
14. CP regulator, short, rated at 0-300psi, awsome regulator, macro line fitting included. Price: $35 Sold to Chuck.
15. Tray with 2 switch holes and mounting screws. A couple of scratches aroung the screw holes. Price: $15 Sold to Jesse, combo deal
16. Stock trigger frame, stock grips, s4 bearing trigger, magnetic trigger mod. Price: $30 Sold to Darryl
18. Vaporworks VLink cable and Software. Price: $24 Sold to kennedy
19. DOP drop foward, macro line fitting, smart parts gauge ( gauge is not accurate ), and a custom dovetail mount to mount the on off directly to the bottom of the grip, includes screws. Price: $17 Sold to Chuck G with asa and gauge for $23
20. Empire 4+5 pack, never used, won at tournement, size s/m, would be good for thin or smaller players. Price: $20 Sold to Norbert
21. Stock barrel. Price: $12 Keeping to use for reball practice, then I wont feel bad about shooting dirty reballs
22. 32 degrees carbon fiber 16 inch barrel, cocker thread, I wet sanded the stainless part to get paint to stick, still did not stick, stripped the paint off and polished it back up, not as polished as factory, but close, this is an accurate and quiete barrel. Price: $35 Sorry, I decided to keep this.
24. Center flag wrapped tank, 68ci 4500psi, retest in 12.09, puts out about 750-800psi, comes with tank cover and nipple cover. No nicks or scratches on tank. Almost 4 years before it needs hydrotested. Price: $100 Sold to holygoalie13
When an item is sold, I will mark it as such and list the buyer next to that item so that they know I am not double selling. I will not hold any items, if you want it, pay for it. Ask questions before you pay. If someone happens to pay for an item after someone else has already paid, the first payment gets it, and the other gets a refund. If you requre USP ground, add $5.
Add a note to the payment as to which item you want, use the item number and description to eliminate confusion. If you requre alternate shipping list it in the note. I will only ship to your paypal confirmed address.
Ask questions.
Need more pics, tell me what you need.
I preffer email. I can read my pm, but I am having a hard time getting them to send.
You get delivery confirmation / tracking numbers as soon as I print the labels.
Thank you for looking,
Adam Middagh (adammiddagh) adammiddagh @ usermail.com
29592 270th st
Worthington MN 56187
PS.
Everything should ship within 48hrs of payment clearing my paypal account, usually I do my shipping at night and it goes in the next days mail.
My paypal account is my email, adammiddagh @ usermail.com
Adam Middagh, adammiddagh @ usermail.com
29592 270th st
Ebay Username: amiddagh
ICDO feedback:
www.icd-owners.com/htm...pic&t=7730
mxsuprastang
PostPosted: Tue Jan 10, 2006 6:45 am    Post subject:
pm'd you
adammiddagh
PostPosted: Tue Jan 10, 2006 11:06 am    Post subject:
Evil Pipe pending to mxsuprastang.
UP.....
29592 270th st
ICDO feedback:
adammiddagh
PostPosted: Tue Jan 10, 2006 11:36 am    Post subject:
Do not pm me, send me an email.
Use email
No PM.
You can also post to this listing.
29592 270th st
ICDO feedback:
Monke
PostPosted: Tue Jan 10, 2006 1:30 pm    Post subject:
$20 for the vlink/software?
let me know.
Embrassing...no one realized that the sniper was sitting in that tree the whole time....
vc style....
DarrylHadfield: hehe.. American Beer.. is like sex in a canoe.. F**king close to water!
adammiddagh
PostPosted: Tue Jan 10, 2006 2:03 pm    Post subject:
let me know.
I can do $24 and if payment clears in the next half hour, I will get it
to the post office before they close today.
If that will work for you, paypal me at adammiddagh @ usermail.com with vLink in the note.
29592 270th st
ICDO feedback:
Bushball
PostPosted: Tue Jan 10, 2006 2:11 pm    Post subject:
interested in the alamo city bolt... email sent.
adammiddagh
PostPosted: Tue Jan 10, 2006 3:00 pm    Post subject:
Everything is open to negotiation and package deals.
Email me an offer, worst that will happen is that I say
no.
Email me, I will respond to any offer, I may say no,
but I will respond.
Try no to use pm, I cannot get my replys to send half
of the time, I do not know whats going wrong.
29592 270th st
ICDO feedback:
dave187
PostPosted: Tue Jan 10, 2006 3:27 pm    Post subject:
does the ebay valve come with the cupseal? also do you really expect to get 70 out of that ram?
adammiddagh
PostPosted: Tue Jan 10, 2006 3:33 pm    Post subject:
The ebay valve comes with the cup seal that was shipped with it.
I started high on some of the items because I knew someone would
try to haggle with me. If you want it, make me an offer.
Thanks,
29592 270th st
ICDO feedback:
Page 1 of 5
Wtb Indian creek design solenoid 982030
Last post by Tjone in ICD Gear Forum on May 30, 2018 at 21:33:32
Last post by lasoyapro in Paintball talk on May 25, 2018 at 18:38:48
Last post by Walkertl in ICD Mech Markers on May 15, 2018 at 19:06:39
Last post by 63VDub in ICD Gear Forum on May 02, 2018 at 17:01:55
Last post by Tzarector in ICD Gear Forum on Mar 30, 2018 at 04:05:35
Last post by Un2XS in PRP General Forum on Mar 25, 2018 at 21:32:43
WTB: Promaster
Last post by ViperXT in ICD Gear Forum on Mar 23, 2018 at 16:16:25
