Visitors: 87
Total: 87
28: Home
35: Your Account
75: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › A Persistent and annoying leak :: Archived
bagel
PostPosted: Fri Dec 29, 2006 6:15 pm    Post subject: A Persistent and annoying leak
Alright...so i have this leak...i used some lube to find bubbles and i found the leak to be between the manifold and the gasket or the noid and the gasket right below one of the screws that screws the noid into the manifold. I tried lubing the gasket to swell it up...loosening and tightening the screws etc...here are some pics to help comprehension of this leak...i need some serious help on this one guys
thanks,
aaron
more pics upon request
NDFS7 and T2'd B2k4pds
Wild Adventure Paintball, Zamora, CA
PostPosted: Fri Dec 29, 2006 9:13 pm    Post subject: Re: A Persistent and annoying leak
Is that the t2 manifold? with where it is at, i say it's one of two things:
1) bad gasket. easily solved at airsoldier.com
2) hole for the noid screw is not deep enough. solved one of several ways:
a)get a new manifold
b)send that one back to be redrilled/tapped
c)shorten that screw a smidgen <- my favorite, but you may lose some holding strength by removing thread length.
Compulsion
PostPosted: Fri Dec 29, 2006 9:21 pm    Post subject: Re: A Persistent and annoying leak
When I had a leak there it was due to an improperly machined manifold. I tried everything I knew to get rid of the leak. Nothing I did would solve it for good. I couldn't figure it out.
Finally sent it in and ICD fixed it. Of course, that doesn't apply to you. I'd suggest putting on your old manifold and see if that fixes the problem. If so, you know you'll need to speak to Greg about the one you have.
--Ron
Old Man Militia: Aim, Eliminate, Take a Nap
What I'm shooting
bagel
PostPosted: Fri Dec 29, 2006 9:25 pm    Post subject: Re: A Persistent and annoying leak
yea it is a t2 but here is the thing...it is already my second manifold...i guess ill try the gasket option however...
any other ideas?
EDIT: I cant find that gasket anywhere on asp...
PostPosted: Fri Dec 29, 2006 11:04 pm    Post subject: Re: A Persistent and annoying leak
I would just reverse the gasket.
bagel
PostPosted: Fri Dec 29, 2006 11:26 pm    Post subject: Re: A Persistent and annoying leak
yea but the thing is is the gasket is unreversible...it only works one side
PostPosted: Sat Dec 30, 2006 12:23 am    Post subject: Re: A Persistent and annoying leak
Drop haveblue an email over there at ASP, dollars to donuts says he has some HEA gaskets.
handyandy
PostPosted: Sat Dec 30, 2006 1:14 am    Post subject: Re: A Persistent and annoying leak
my T2 manifold did the same thing.
i sent everything to Greg and he fixed it right up and mow it works perfectly.
he said that he had a few bad manifolds.
talk to Greg I'm sure he has a solution.
Andy
Selling all my gear, check out the BST
BTW I'm dyslexic... I know I cant spell.
CJLOVI
PostPosted: Sat Dec 30, 2006 4:22 am    Post subject: Re: A Persistent and annoying leak
I also had a bad manifold! Greg took care of it right away!
View user's profile Send e-mail Visit poster's website Yahoo Messenger Photo Gallery
bagel
PostPosted: Sat Dec 30, 2006 3:01 pm    Post subject: Re: A Persistent and annoying leak
alright...i guess ill just have to send it back to him...
i just hate the time it takes to get there and back
any other suggestions before i send it?
