Latest: YAz45mmi
Overall: 7922
Visitors: 134
Total: 134
39: Your Account
75: Home
83: Home
86: Home
125: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › PDS not functioning :: Archived
PDS not functioning
CheasenKrackerz
PostPosted: Fri Jan 26, 2007 5:03 pm    Post subject: PDS not functioning
I'm starting to feel like all I do is break this gun... finally got the air flowing properly, but in the process of checking the valve , I pulled the wire off of the PDS switch(it would be the wire on the end not the middle of the switch) tried flipping the switch and wrapping the Yellow line through the connector(don't have a soldering gun right now) but the PDS isn't operating now, I went back through and checked for pinched wires, nothing there, is it a matter of I need to just resolder the connection onto the switch, or is there something else I can try first
Dyemonic
PostPosted: Fri Jan 26, 2007 7:49 pm    Post subject: Re: PDS not functioning
So the wire is pulled out of the switch and there is no visible wire on the switch?
If you can still see some wire on the switch, make the wiring inside of each of them touch, and test the pds then, and make sure the wires stay connected, but you should get a soldering iron and solder the wires together for sure.
www.gatormotorsports.com
CheasenKrackerz
PostPosted: Fri Jan 26, 2007 9:38 pm    Post subject: Re: PDS not functioning
there is still solder and wire on the switch itself, I tried using the other side of the switch(wrapping it through it) and it didn't work. I tried touching them together, but its difficult to test with everything taken apart, I'll try resoldering it.
adidas online kopen
Last post by YAz45mmi in Calendar of Events on Oct 24, 2020 at 04:06:09
NikeLab Dunk Lux SP Dark
Last post by YAz45mmi in Off Topic on Oct 24, 2020 at 03:59:37
Converse har spillet med
Last post by YAz45mmi in Paintball talk on Oct 24, 2020 at 03:51:39
adidas EQT-Kissen ADV
Last post by YAz45mmi in PRP General Forum on Oct 24, 2020 at 03:45:37
adidas solar glide st 3 rosse
Last post by igo5apzv in Calendar of Events on Oct 22, 2020 at 02:08:20
adidas solar glide st heren
Last post by igo5apzv in Off Topic on Oct 22, 2020 at 02:05:46
adidas solar glide 19 negras
Last post by igo5apzv in Paintball talk on Oct 22, 2020 at 02:02:12
Last post by Tzarector in ICD Gear Forum on Oct 15, 2020 at 13:24:07
new balance 1530 saldi online
Last post by Johnonsmith in ICD Gear Forum on Sep 17, 2020 at 08:37:29
puma italia scarpe
Last post by Johnonsmith in PRP General Forum on Sep 17, 2020 at 08:27:24
