Visitors: 65
Total: 65
Forums › Marker Talk › Problem/Tech forum :: Archives › getting hpr off :: Archived
getting hpr off
wantafreestyle
PostPosted: Tue Feb 06, 2007 1:10 am    Post subject: getting hpr off
hey i have an fs8 and i am trying to get the asa part that screws into the gun off from the main part of the hpr. i tryed a strap wrench and it would not move. if would could tell me how that would be great bc i have to clean the reg.
Rocking the Fs8 baby........ Icd all the way!\r\n\r\nPain is weakness leaving the body: best quote!
Gibson
PostPosted: Tue Feb 06, 2007 3:04 am    Post subject: Re: getting hpr off
the guage might be hitting the top of the Hpr inside the ASA. try backing out the guage a few turns, and then unscrewiong the reg
Black 2k3 BKO, sp mod, zenitram asa, zenitram valve, micro rock lpr, sidewinder hpr, vapor bolt, mighty max, bizerk barrel system (owns) blue led :p, crossfire 68/3k, evo w/ zboard.
View user's profile Send e-mail Visit poster's website AIM Address Yahoo Messenger
mckvader
PostPosted: Tue Feb 06, 2007 8:17 am    Post subject: Re: getting hpr off
Have you removed it before? If not it is most likely just "set" in place try heating it up with a blow dryer then unscrewing it. I mean "HEAT", on high and make sure itts warm then give it a shot it might just need to be broken free for the first time.
A-5 E-Grip/JCS/TechTMods - SP ION T-board/TechTL7 - ICD Promaster **Nox'd**
WWW.Fatalimpactpaintball.com
t0nnn
PostPosted: Sun Feb 11, 2007 7:49 pm    Post subject: Re: getting hpr off
i'm having the same exact problem only with a friends promaster stock reg. We heated it up and still can't get the top part off, any other solutions?
feedback
bagel
PostPosted: Mon Feb 12, 2007 12:17 am    Post subject: Re: getting hpr off
Alright. What I am about to suggest is mainly used ONLY if you do not want to use the regulator that you are about to take off. However, this method is virtually foolproof.
Remove gauge from port.
Insert metal dowel/rod/something hard
Vice Grip on regulator.
Using the gauge port for leverage and the vice grip for friction, you should easily be able to remove it. Unfortunately, this method leaves some visual scars.
As far as the heating goes, different types of adhesives and loctite require relatively high temperatures in order to loosen their grip.
In my experience, when heating you need to heat it so that it's almost too hot to touch.
A minute on a blow drier just won't cut it.
Hope this helps
NDFS7 and T2'd B2k4pds
Wild Adventure Paintball, Zamora, CA
