Latest: nsgm23ip
Overall: 7935
Visitors: 221
Total: 221
18: Home
89: Private Messages
111: Home
127: Home
131: Home
138: Home
159: Photo Gallery
160: Home
162: Home
171: Home
172: Home
179: Home
184: Photo Gallery
186: Photo Gallery
191: Photo Gallery
194: Your Account
199: Photo Gallery
200: Photo Gallery
203: Photo Gallery
207: Photo Gallery
211: Photo Gallery
221: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › chaos board question :: Archived
Mantis
PostPosted: Sun Sep 28, 2003 3:49 pm    Post subject: chaos board question
I just installed a new chaos baord for my b2k3 with pds it works great except for one problem. When I walk the trigger to get the maxmum bps I chop paint. I bought the NPPL leagle board which is semi auto only. But I would like to know if it can still be reprogramed to give the eye more of a delay so it does not chop nomatter how fast I try to shoot. I also installed the new micro switch which I am sure helps it fire faster I know I could slow down the gun by installing the old switch but I would like to keep it the way it is and get the eye to do its job and slow down the marker.
Goldie
PostPosted: Sun Sep 28, 2003 4:41 pm    Post subject:
yes, you can set for a longer delay or so it won't shoot at all until it sees paint.
You can download instructions on the manuals and files sections here.
Sangerpb
PostPosted: Sun Sep 28, 2003 5:36 pm    Post subject:
what type of hopper do you have, I'd say get a halo, that is what I"m doing Smile
Mantis
PostPosted: Sun Sep 28, 2003 5:41 pm    Post subject: follow up
I have an evo 2 but van still out shoot it, I'm going to reprogram the eye so that it does not shoot till it sees paint. What do the instructions meen when they say disengage the tourney lock? What setting makes the marker not fire untill it sees paint? Is it the drop shot after timer setting? thanks for all of your help!
icdown
PostPosted: Sun Sep 28, 2003 5:46 pm    Post subject:
remove tourney lock means remove the jumper.
you want drop shot after timer.
Mantis
PostPosted: Sun Sep 28, 2003 6:20 pm    Post subject:
Yes I read that what is the jumper is it even on the semi auto only board?
Keo
PostPosted: Sun Sep 28, 2003 6:54 pm    Post subject:
the jumper is one the max board, semi don't, I saw delay the eye timming alittle and see what happens, and drop your bps to 15ish
Mantis
PostPosted: Sun Sep 28, 2003 7:22 pm    Post subject:
Ok changed the settings but why does it need to fire one shot before the eye takes effect. I.E even if not paint is present the marker will still fire once before it stops shooting? This will cause problems right because if the board does not notice there is no paint till it is to late then it is all over rite I will have already choped.
Keo
PostPosted: Sun Sep 28, 2003 7:28 pm    Post subject:
if you dry fire with the eye one, it will dely the firing, meaning, you'll shoot alot slower. but it will fire if there no ball there, like ANY eye system
Mantis
PostPosted: Mon Sep 29, 2003 4:58 pm    Post subject:
Not true the stock board did not shoot at all if there was no paint in the marker. You could not dry fire even once if the eye was turned on. But the chaos eye seems to work any way eith the drop shot turned on. Did not chop with two loaders full of paint going through it. Thank you every one for your help. This is a very helpfull forum.
nike air foamposite
Last post by Angftr12 in Calendar of Events on Mar 20, 2021 at 10:50:17
adidas superstar pas cher
Last post by Angftr12 in Off Topic on Mar 20, 2021 at 10:43:48
