Visitors: 284
Total: 284
114: Your Account
118: Home
153: Home
156: Photo Gallery
160: Photo Gallery
165: Photo Gallery
166: Photo Gallery
173: Photo Gallery
174: Photo Gallery
181: Photo Gallery
183: Photo Gallery
186: Photo Gallery
187: Photo Gallery
189: Your Account
190: Photo Gallery
193: Photo Gallery
195: Photo Gallery
196: Photo Gallery
197: Photo Gallery
198: Photo Gallery
199: Photo Gallery
201: Home
203: Photo Gallery
204: Photo Gallery
205: Photo Gallery
206: Photo Gallery
207: Photo Gallery
208: Photo Gallery
209: Photo Gallery
210: Photo Gallery
211: Photo Gallery
212: Photo Gallery
213: Photo Gallery
214: Photo Gallery
217: Photo Gallery
218: Photo Gallery
219: Photo Gallery
220: Photo Gallery
221: Photo Gallery
222: Photo Gallery
223: Photo Gallery
224: Photo Gallery
225: Photo Gallery
226: Photo Gallery
227: Photo Gallery
229: Photo Gallery
230: Photo Gallery
231: Photo Gallery
233: Photo Gallery
234: Photo Gallery
235: Photo Gallery
236: Photo Gallery
237: Your Account
238: Photo Gallery
239: Photo Gallery
240: Photo Gallery
241: Photo Gallery
242: Photo Gallery
243: Photo Gallery
245: Photo Gallery
246: Photo Gallery
249: Photo Gallery
250: Photo Gallery
251: Photo Gallery
252: Photo Gallery
253: Photo Gallery
255: Photo Gallery
256: Photo Gallery
257: Photo Gallery
258: Photo Gallery
259: Photo Gallery
260: Photo Gallery
261: Photo Gallery
262: Photo Gallery
263: Photo Gallery
264: Photo Gallery
265: Photo Gallery
266: Photo Gallery
267: Photo Gallery
268: Photo Gallery
271: Photo Gallery
272: Photo Gallery
273: Photo Gallery
274: Forums
275: Photo Gallery
276: Photo Gallery
277: Photo Gallery
278: Photo Gallery
279: Photo Gallery
280: Photo Gallery
281: Photo Gallery
282: Photo Gallery
283: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › chaos board question :: Archived
Mantis
PostPosted: Sun Sep 28, 2003 3:49 pm    Post subject: chaos board question
I just installed a new chaos baord for my b2k3 with pds it works great except for one problem. When I walk the trigger to get the maxmum bps I chop paint. I bought the NPPL leagle board which is semi auto only. But I would like to know if it can still be reprogramed to give the eye more of a delay so it does not chop nomatter how fast I try to shoot. I also installed the new micro switch which I am sure helps it fire faster I know I could slow down the gun by installing the old switch but I would like to keep it the way it is and get the eye to do its job and slow down the marker.
Goldie
PostPosted: Sun Sep 28, 2003 4:41 pm    Post subject:
yes, you can set for a longer delay or so it won't shoot at all until it sees paint.
You can download instructions on the manuals and files sections here.
Sangerpb
PostPosted: Sun Sep 28, 2003 5:36 pm    Post subject:
what type of hopper do you have, I'd say get a halo, that is what I"m doing Smile
Mantis
PostPosted: Sun Sep 28, 2003 5:41 pm    Post subject: follow up
I have an evo 2 but van still out shoot it, I'm going to reprogram the eye so that it does not shoot till it sees paint. What do the instructions meen when they say disengage the tourney lock? What setting makes the marker not fire untill it sees paint? Is it the drop shot after timer setting? thanks for all of your help!
icdown
PostPosted: Sun Sep 28, 2003 5:46 pm    Post subject:
remove tourney lock means remove the jumper.
you want drop shot after timer.
Mantis
PostPosted: Sun Sep 28, 2003 6:20 pm    Post subject:
Yes I read that what is the jumper is it even on the semi auto only board?
Keo
PostPosted: Sun Sep 28, 2003 6:54 pm    Post subject:
the jumper is one the max board, semi don't, I saw delay the eye timming alittle and see what happens, and drop your bps to 15ish
Mantis
PostPosted: Sun Sep 28, 2003 7:22 pm    Post subject:
Ok changed the settings but why does it need to fire one shot before the eye takes effect. I.E even if not paint is present the marker will still fire once before it stops shooting? This will cause problems right because if the board does not notice there is no paint till it is to late then it is all over rite I will have already choped.
Keo
PostPosted: Sun Sep 28, 2003 7:28 pm    Post subject:
if you dry fire with the eye one, it will dely the firing, meaning, you'll shoot alot slower. but it will fire if there no ball there, like ANY eye system
Mantis
PostPosted: Mon Sep 29, 2003 4:58 pm    Post subject:
Not true the stock board did not shoot at all if there was no paint in the marker. You could not dry fire even once if the eye was turned on. But the chaos eye seems to work any way eith the drop shot turned on. Did not chop with two loaders full of paint going through it. Thank you every one for your help. This is a very helpfull forum.
