Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Need better air efficiency :: Archived |
Need better air efficiency Have a problem with your marker? Ask here
Go to page Previous 1, 2, 3 Next
Author |
Message |
kruppy Pro Baller
Posted: Tue Apr 03, 2007 1:34 pm Post subject: Re: Need better air efficiency |
You don't need to cover the hole... Just teflon tape the gauge in... That's where the leak is more then likely occuring.. if it's leaking out that hole.. u need a new gauge or block it off
_________________ 2k1 MacDev Sonic Autococker
- E-Bladed (undrilled)
- Shocktech Feedneck
- 15* Asa |
Back to top |
twinki Novice
Posted: Tue Apr 03, 2007 2:22 pm Post subject: Re: Need better air efficiency |
a new gauge is cheap too, like $5-10.
Back to top |
immortal_clown Novice
Posted: Tue Apr 03, 2007 4:58 pm Post subject: Re: Need better air efficiency |
Maybe my current valve just needs lube or a new oring ? is that possible ? should i crack it open and have a looksie ?
Back to top |
twinki Novice
Posted: Tue Apr 03, 2007 5:01 pm Post subject: Re: Need better air efficiency |
u can do that but most ppl woudl just suggest a new valve anyway.
Back to top |
Big_Mac Amateur
Joined: Sep 23, 2003 Posts: 486 Location: in a bunker in Iraq
Posted: Tue Apr 03, 2007 11:56 pm Post subject: Re: Need better air efficiency |
back on topic...I know, such a drag!
Even a stock Bushmaster shouldn't be a gas hog. Even before mods you should still get 900 balls or so out of a 68/3000.
_________________ Stupidity Kills |
Back to top |
twinki Novice
Posted: Wed Apr 04, 2007 1:13 am Post subject: Re: Need better air efficiency |
not really, b2ks are kinda known for being gass hogs. with ups they are no longer gas hogs if u balance ur regs and set everything up rite
Back to top |
Posted: Wed Apr 04, 2007 7:55 am Post subject: Re: Need better air efficiency |
hard to know what my hpr is set at with a broken guage -.-
Back to top |
twinki Novice
Posted: Wed Apr 04, 2007 9:34 am Post subject: Re: Need better air efficiency |
well if its broken........replace it
Back to top |
kruppy Pro Baller
Posted: Wed Apr 04, 2007 11:34 am Post subject: Re: Need better air efficiency |
immortal_clown wrote: |
Maybe my current valve just needs lube or a new oring ? is that possible ? should i crack it open and have a looksie ? |
Won't do anything to lube your stock valve or replace the o-ring. The the inlet hole that gets you. Buy an aftermarket valve to drop the pressure down.
- 15* Asa |
Back to top |
twinki Novice
Posted: Wed Apr 04, 2007 2:07 pm Post subject: Re: Need better air efficiency |
twinki wrote: |
u can do that but most ppl woudl just suggest a new valve anyway. |
told you
Back to top |
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
