Latest: nsgm23ip
Overall: 7935
Visitors: 148
Total: 148
07: Home
32: Top
68: Home
76: Home
91: Home
106: Home
133: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › AKA SCM :: Archived
AKA SCM
PostPosted: Tue Jun 12, 2007 7:28 pm    Post subject: AKA SCM
I recently picked up a new SCM III for a bushmaster. When I installed it, the spring was clearly under higher compression. I removed it and compared, and the SCM is about 1/8-1/4" longer than stock. Is this right, or did I get a wrong product? I am worried because it is now hard to force the valve open. I can't test because I still don't have the new solenoid. Thanks in advance.
PostPosted: Tue Jun 12, 2007 9:48 pm    Post subject: Re: AKA SCM
The extender shaft in some SCMs was shorter than necessary, so a longer spring is needed... try springs; worst case, cut out enough links to make it the size you need, uncompressed...
Big_Mac
PostPosted: Tue Jun 12, 2007 10:36 pm    Post subject: Re: AKA SCM
or go to your local hardware store and get a lighter/shorter spring, further reducing your LPR setting.
Stupidity Kills
PostPosted: Thu Jun 14, 2007 12:35 pm    Post subject: Re: AKA SCM
Anyone know what the spring rate is for the stock spring? Or, even better, a Mcmaster-carr PN? I don't mind cutting the stock spring, but would like to get a new one if possible.
PostPosted: Thu Jun 14, 2007 1:25 pm    Post subject: Re: AKA SCM
Read. www.icd-owners.com/htm...pic&t=7704
nike air foamposite
Last post by Angftr12 in Calendar of Events on Mar 20, 2021 at 10:50:17
adidas superstar pas cher
Last post by Angftr12 in Off Topic on Mar 20, 2021 at 10:43:48
