Latest: major_movit
Overall: 7915
Visitors: 34
Total: 34
21: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › I need some help, leaking problem... :: Archived
levi333
PostPosted: Wed Jan 07, 2004 9:41 pm    Post subject: I need some help, leaking problem...
Ive got an 03 bko.
when i hook up my HP tank to it, the reg jumps up to around 300 PSI and it slowly comes back down to around 225. The needle also jumps up a bit when i fire.
I can also hear a leak out of the barrel and vert feed.
Any suggestions? ive tried over at pbreview.com, but it didnt help.
I have broken down the whole gun (except the solenoid) and greased all the neccesary parts.
Anybody help me out? its getting frustrating.
Think its the reg? shouldnt this all be covered under the warrenty?
Ive tried contacting ICD directly, but their responses take 2 days, i thought id try and get some help here.
Thanks a bunch, Levi
Heres my contact info if you want it
AIM-foreignkid333
MSN- levi_333 @ msn.com
Silver BKO3´
-CP Reg -12" Silver/Black CP 2pc -Silver Zenitram 45 Magnetic Frame -DYE Carbon Fiber Grips -OTB Blind Bolt -CIP Clamping Rise -AKA Mitey Max -Vapor Valve -Kapp Gauge -WGP Torpedo Drop
CMLM20
PostPosted: Wed Jan 07, 2004 10:59 pm    Post subject:
I would suggest cleaning your HPR for the jumping of the pressure. For the leak down the barrel you need to clean your valve seal or get a new one.
levi333
PostPosted: Wed Jan 07, 2004 11:12 pm    Post subject:
I did clean and grease my HPR(didnt state that above), thanks for the advice though.
as for the valve, im getting a vapor valve real soon, hope that will help.
Silver BKO3´
levi333
PostPosted: Fri Jan 16, 2004 6:28 pm    Post subject:
well, still having problems. i got a new valve seal, greased the regs, still problems.
it seem as if the HP reg is not doing its job, it doesnt want to adjust right, the gauge doesnt move when i adjust it.
i think i might try a new reg, but i want ICD to at least fix/replace the reg i have.
any other advice would be grand.
Silver BKO3´
