Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Horriable BKO effiancy problems :: Archived |
Horriable BKO effiancy problems Have a problem with your marker? Ask here
Author |
Message |
skife Rookie
Posted: Tue Sep 30, 2003 8:32 pm Post subject: Horriable BKO effiancy problems |
I'm running a 2003 BKO with stock reg and a 68/4500 tank with 850 psi output pressure, I'm getting about 200 shots to a 3k fill, whats my problem here?, also i am chronoing at about 285
thanks
Back to top |
dval Novice
Joined: Sep 22, 2003 Posts: 73 Location: Crescent City, Ca.
Posted: Tue Sep 30, 2003 9:08 pm Post subject: |
sounds like your regs are outta wack, what are your regs set too?
i have a similar setup, but i get about 900 to 3000 psi
my hpr is set 215 and my lpr is set ti manual instructions.
and i am shooting 285 +- 5 fps, also have you broken in the regs yet?
but 200 is way low. there are mods you can get but i wouldnt say get just yet, if its still new, just try checking those regs though thats most of the prob. I was blessed with a bko that shot xcellent right outta box
Back to top |
PatrickLee Pleeairsmith.com
Joined: Sep 23, 2003 Posts: 1291 Location: Long Island/Queens
Posted: Tue Sep 30, 2003 9:12 pm Post subject: |
are you leaking? how is tha possible? have you tried taking apart the regs, cleaning and lubing them?
_________________ NYC REVOLUTION |
Back to top |
skife Rookie
Posted: Wed Oct 01, 2003 11:43 am Post subject: |
okay, my HP reg is set to 225 and my LPR i don't know what its set too but i shoot 285 +-5 too, how do i break in my reg, i don't know how old this gun is because i just bought it from the shop but it was sorta used, like somone won it in a tourney and played a couple games with it and then they traded it in or somthing, i don't know how many shots it has through it, i probbly put maybe 500 in it
Back to top |
rt45s Rookie
Posted: Wed Oct 01, 2003 4:37 pm Post subject: |
It should be broken in if you shot 500 and it is used.
Have you dry fired your gun at all??
When dry firing the a bko, they use about 50% more air then normal.
Your regs are probablt dirty like dval said.
Try cleaning them.
Take your hpr apart, then wipe your piston clean, will a clean rag. After dab some lithium grease on it.
Back to top |
kyleschenk Rookie
Joined: Sep 29, 2003 Posts: 36 Location: Ontario, Canada
Posted: Wed Oct 01, 2003 6:01 pm Post subject: |
Im having the same problems. Im running a glad hpr and a micro rock lpr and a red valve, both are clean and lubed. my hpr is set to around 230psi. Any thoughts?
Back to top |
dinger Novice
Joined: Oct 01, 2003 Posts: 52 Location: near cleveland ohio
Posted: Wed Oct 01, 2003 6:57 pm Post subject: |
i just recently lost the poppet spring that goes in the bottom of my HPR..
*** **** im such a ****ing retard who cant **c**** do **** for beans
i suck
Back to top |
camilion705 Novice
Posted: Wed Oct 01, 2003 9:58 pm Post subject: |
Back to top |
dval Novice
Posted: Thu Oct 02, 2003 9:03 am Post subject: |
230 is kinda high on the hpr, i havent heard of many people running that high. But like they thethread above should help
Back to top |
rt45s Rookie
Posted: Thu Oct 02, 2003 2:30 pm Post subject: |
Quote:: |
Im having the same problems. Im running a glad hpr and a micro rock lpr and a red valve, both are clean and lubed. my hpr is set to around 230psi. Any thoughts? |
Wut are you shooting at (fps)?
Thats real high psi if you have a micro rock and a new valve.
Just taking that from my setup, which is close to yours.
mines running at 115psi and it puts out 268 fps +-2.
Back to top |
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
