Latest: dm822d5x
Overall: 7932
Visitors: 171
Total: 171
42: Your Account
95: Home
119: Home
122: Home
124: Home
139: Home
147: Home
149: Home
150: Home
153: Home
166: Photo Gallery
Forums › General › Paintball talk :: Archives › Macro Line Fittings :: Archived
Macro Line Fittings
BUSHWiiCK
PostPosted: Sat Jul 17, 2010 12:58 am    Post subject: Macro Line Fittings
Ok this will be my first time actually inserting my macro line. i usually go with steel braided hose that you just twist into the fitting. But for macro line the part where i insert the macro line into the fitting i need to add loctite am i correct?
all help is appreciated. Very Happy
Thanks,
Jordan
Apologies. It's been a while since I've been working around Chicanos. I guess I meant to say cabron.
PostPosted: Sat Jul 17, 2010 2:08 am    Post subject: Re: Macro Line Fittings
NOOO, There is an o-ring in there tat seals against the macro.
PostPosted: Sat Jul 17, 2010 2:39 am    Post subject: Re: Macro Line Fittings
i use teflon tape. are you talking about where the line goes into the fitting or the fitting into the regulator/air source?
PostPosted: Sat Jul 17, 2010 4:25 am    Post subject: Re: Macro Line Fittings
Nope you just shove the hose in as far as it will go. Make sure the hose is cut nice on the end so it seals. I use a razor blade or a cigar cutter to trim the ends.
BUSHWiiCK
PostPosted: Sat Jul 17, 2010 6:45 pm    Post subject: Re: Macro Line Fittings
Will do, Thanks guys. so all i have to do is have a straight cut upon the end of the macro line and just shove it into the fitting ?
PostPosted: Sat Jul 17, 2010 7:02 pm    Post subject: Re: Macro Line Fittings
yeah. i use dikes to cut it usually. make sure you shove it in all the way. it does not hurt to leave yourself a little extra line.
PostPosted: Sat Jul 17, 2010 7:43 pm    Post subject: Re: Macro Line Fittings
they also make macro line cutters....me and dad both have them, and there cheap to pcik up.
BUSHWiiCK
PostPosted: Sat Jul 17, 2010 8:10 pm    Post subject: Re: Macro Line Fittings
i just might look into picking up a pair of macro line cutters. Thanks for the info.
nike air max 95 grey/brown
Last post by dm822d5x in Paintball talk on Feb 07, 2021 at 02:59:47
nike air force 1 shadow femme
Last post by zspgrons in Freestyle General Talk on Feb 02, 2021 at 06:49:04
nike air force 1 shadow blau
Last post by zspgrons in Paintball talk on Feb 02, 2021 at 06:45:15
Last post by maloneoni in Calendar of Events on Jan 25, 2021 at 03:02:04
