Visitors: 91
Total: 91
72: Groups
Forums › General › Paintball talk :: Archives › Realy po'd with icd... :: Archived
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Oct 12, 2011 11:01 pm    Post subject: Re: Realy po'd with icd...
As far as I can tell, everything looks good. That last picture is the spacer from between the spring and the set screw? Make sure the little nubbin is facing into the spring.
PostPosted: Thu Oct 13, 2011 8:05 am    Post subject: Re: Realy po'd with icd...
^ It is. It is faceing correctly.
PostPosted: Thu Oct 13, 2011 8:39 pm    Post subject: Re: Realy po'd with icd...
So where are we at right now on this one?
PostPosted: Thu Oct 13, 2011 8:42 pm    Post subject: Re: Realy po'd with icd...
Everything looks, fits, and seems correct. But somewere, deep in the viens of this marker, there is a little spirit that is causing a diruption.
Do you have the regulators balanced correctly now?
PostPosted: Thu Oct 13, 2011 8:45 pm    Post subject: Re: Realy po'd with icd...
Not sure... i still cant figure that part out.
PostPosted: Thu Oct 13, 2011 8:47 pm    Post subject: Re: Realy po'd with icd...
Ah, therein lies your problem.
PostPosted: Thu Oct 13, 2011 8:48 pm    Post subject: Re: Realy po'd with icd...
How do you balance the regs if the reg wont go up above 200 psi anyways?
PostPosted: Thu Oct 13, 2011 8:50 pm    Post subject: Re: Realy po'd with icd...
Bottom out the LPR before you play with the HPR. When you turn up the HPR, put a squeegee or a stick of macro line in the breech when you do so.
Neither your detonator nor your ICD HPR go above 200?
PostPosted: Thu Oct 13, 2011 8:54 pm    Post subject: Re: Realy po'd with icd...
Both wont push 200psi.
Page 3 of 5
