Visitors: 78
Total: 78
08: Your Account
16: Your Account
74: Your Account
Forums › Buy/Sell/Trade › ICD Gear Forum :: Archives › brass guide for a LPR :: Archived
elguapo
PostPosted: Sat Nov 26, 2011 5:35 am    Post subject: brass guide for a LPR
I am missing the brass guide or "coin" that the spring in the LPR sits on. Does anybody have one? Or does anyone have any idea what might work in place of it?
Norbinc
PostPosted: Sun Nov 27, 2011 12:46 am    Post subject: Re: brass guide for a LPR
That should be the ram,correct me if I'm wrong,but yea quite a few here should have one.
Take you kids paintballing its the only time you can shoot them and get away with it.
Silver Karnivor:
s1083.photobucket.com/...030224.jpg
elguapo
PostPosted: Sun Nov 27, 2011 12:55 am    Post subject: Re: brass guide for a LPR
It is the little coin shaped washer that sets in the bottom of the lpr. The set screw in the lpr pushes aginst it and thus controls the air to the ram. If you have some I would be greatful if you could help me out
PostPosted: Sun Nov 27, 2011 12:57 am    Post subject: Re: brass guide for a LPR
What model marker? I assume it your bko correct?
Norbinc
PostPosted: Sun Nov 27, 2011 1:03 am    Post subject: Re: brass guide for a LPR
Oh, sorry other end,yes BKO or Bushy should work,can't remember what its called.One of the fine regulars on here should have one.
Silver Karnivor:
PostPosted: Sun Nov 27, 2011 1:04 am    Post subject: Re: brass guide for a LPR
OH!!!! The Plunger!
PostPosted: Sun Nov 27, 2011 2:06 am    Post subject: Re: brass guide for a LPR
It's the brass disk between the lpr adjustment screw and the lpr spring. It's been a while since I've searched for the front block you are looking for I got mine at the end of the new parts craze for these markers so they might be a bit harder to find.
You may be able to make one but if it isn't the same thickness as stock it will change the spring rate and will make it harder to adjust properly.
Someone help this guy out I wish I could but for that part I'm taped out.
I just tried to search for a zenitram from block to no avail. Unfortunately the market for these is dying. Your best bet is here.
PostPosted: Sun Nov 27, 2011 2:12 am    Post subject: Re: brass guide for a LPR
Ive got one from a broken icd hpr, it in good condition, if it is the plunger.
pm me.
PostPosted: Sun Nov 27, 2011 2:13 am    Post subject: Re: brass guide for a LPR
does anyone have a picture of this, and is it found on B2Ks? i have some stock HPR regs that i don't need/use, and would be willing to strip this off, to keep another gun running.
PostPosted: Sun Nov 27, 2011 2:16 am    Post subject: Re: brass guide for a LPR
www.icd-owners.com/htm...=23&pos=71
Lpr internals... piece under the spring...
