Latest: nsgm23ip
Overall: 7935
Visitors: 397
Total: 397
18: Your Account
28: Your Account
86: Home
92: Home
155: Your Account
160: Photo Gallery
163: Photo Gallery
181: Photo Gallery
183: Photo Gallery
188: Your Account
190: Photo Gallery
195: Photo Gallery
199: Photo Gallery
200: Home
215: Photo Gallery
217: Home
224: Home
230: Photo Gallery
241: Photo Gallery
244: Photo Gallery
253: Photo Gallery
257: Forums
262: Forums
263: Forums
265: Photo Gallery
267: Home
271: Photo Gallery
272: Photo Gallery
273: Forums
274: Forums
275: Home
277: Forums
279: Forums
280: Forums
281: Forums
283: Forums
285: Forums
286: Forums
287: Forums
288: Forums
289: Photo Gallery
290: Forums
291: Photo Gallery
292: Forums
293: Photo Gallery
294: Forums
295: Forums
296: Home
297: Forums
298: Forums
299: Photo Gallery
300: Forums
301: Forums
302: Photo Gallery
303: Forums
304: Forums
305: Forums
306: Forums
307: Your Account
308: Forums
309: Photo Gallery
310: Forums
311: Forums
312: Forums
313: Forums
314: Forums
315: Forums
316: Forums
317: Forums
318: Forums
319: Forums
320: Forums
321: Forums
322: Photo Gallery
323: Forums
324: Forums
325: Forums
326: Forums
327: Forums
328: Forums
329: Forums
330: Forums
331: Forums
332: Forums
333: Forums
334: Forums
335: Photo Gallery
336: Forums
337: Forums
338: Forums
339: Forums
340: Forums
341: Forums
342: Forums
343: Forums
344: Forums
345: Forums
346: Forums
347: Forums
348: Forums
349: Your Account
350: Forums
351: Forums
352: Forums
353: Forums
354: Forums
355: Photo Gallery
356: Forums
357: Photo Gallery
358: Forums
359: Forums
360: Forums
361: Forums
362: Photo Gallery
363: Photo Gallery
364: Forums
365: Forums
366: Forums
367: Forums
368: Forums
369: Forums
370: Home
371: Forums
372: Forums
373: Forums
374: Forums
375: Home
376: Forums
377: Forums
378: Forums
379: Forums
380: Forums
381: Forums
382: Forums
383: Forums
384: Forums
385: Forums
386: Forums
387: Home
388: Home
389: Photo Gallery
390: Forums
391: Forums
392: Forums
393: Forums
394: Forums
395: Forums
396: Home
397: Forums
Forums › General › Paintball talk :: Archives › Bob Long Defiant :: Archived
Bob Long Defiant
spaz66
PostPosted: Thu Jan 26, 2012 11:28 pm    Post subject: Bob Long Defiant
I just received this marker,Im wandering if someone knows a little about it,the board reads ICD 8200,and the noid has a sticker on it that reads Indian Creek Designs 982030.The marker has a leak,ive taken out the noid and cleaned the piston and relubed it,but the leak is still present,the marker will shoot even with the leak im wandering if anyone knows any info on this beast.
Together we will win
PostPosted: Thu Jan 26, 2012 11:40 pm    Post subject: Re: Bob Long Defiant
Stock Deffy with a Ripper Frame, Lapco Vert and old school VW Rock adapter. Where's the leak from? Might check the orings on the ram housing, and the ram piston oring. After that, I would check the orings between the manifold and body.
KPCSpb
PostPosted: Thu Jan 26, 2012 11:43 pm    Post subject: Re: Bob Long Defiant
Can you tell where the leak is located at or what area the leak is ?
Ken W
I'm just a glorified drill press operator.
spaz66
PostPosted: Thu Jan 26, 2012 11:53 pm    Post subject: Re: Bob Long Defiant
it sounds like its from above the noid,around the block the noid is screwed into
KPCSpb
PostPosted: Thu Jan 26, 2012 11:57 pm    Post subject: Re: Bob Long Defiant
There is a O-ring in between the body & manifold.
There is a gasket in between the noid and manifold.
I would check both of these to make sure they are making a sealed.
Ken W
you need to eliminate the ram orings first, because if the center oring on the housing or the oring on the ram shaft is nicked, it will cause the solenoid to vent out of the exhaust. Also make sure your LPR is not set too high, as that will cause the solenoid to vent.
Edit: what Ken said, too.
spaz66
PostPosted: Fri Jan 27, 2012 12:01 am    Post subject: Re: Bob Long Defiant
kk will check it,Stock Deffy ? not up on the terminology,guy at the paintball shop seen i run a promaster and thought i might be interested in this marker and gave me an awesome deal.
PostPosted: Fri Jan 27, 2012 12:05 am    Post subject: Re: Bob Long Defiant
Deffy = Defiant. Bob Long variant of the Bushmaster. Yours has some nice upgrades for it's day.
PostPosted: Fri Jan 27, 2012 12:11 am    Post subject: Re: Bob Long Defiant
Deffy = short for Defiant
Defiant where Private Label Bushmaster 2000 made by ICD for Bob Long before the Intimidator was made.
that is a great looking gun, with a lot of choice parts, though on the older side, but still good.
you have the a stock board, which isn't bad, semi, 3, 6, full auto(semi is unlimited, but 3,6,FA is limited to 9). my first thing is to upgrade the harness, but i'm biased about that Wink
spaz66
PostPosted: Fri Jan 27, 2012 12:13 am    Post subject: Re: Bob Long Defiant
Thanks ill get to work on it and post back when i get results,ram housing is very dry and dirty so possibly just some tlc and lube and it will be ok o-rings are in good shape,ram slides smooth without too much resistance just like my PM.
nike air foamposite
Last post by Angftr12 in Calendar of Events on Mar 20, 2021 at 10:50:17
adidas superstar pas cher
Last post by Angftr12 in Off Topic on Mar 20, 2021 at 10:43:48
