Latest: Mmoak2018
Visitors: 153
Total: 153
25: Your Account
87: Home
93: Home
118: Home
149: Home
150: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Velocity Control :: Archived
Velocity Control
igjoe
PostPosted: Sun Jan 25, 2004 8:28 pm    Post subject: Velocity Control
I've set my HPR to 200psi, I've backed my micro rock LPR off and slowly adjusted it in until it cycles then gave it a 1/4 - 1/2 turn. I fire a shot and the ball pops out about 5 feet (no chrono reading). I then slowly start to increase the inline reg to increase velocity. I've cranked that sucker up as high as 450psi and I can't get anything higher than 175fps. What gives?
I've noticed that if I keep my HPR at 200psi and start to crank up the LPR I get velocity setting as high as 300fps.
What should I do or what am I doing wrong? Question
lil_tyrant
PostPosted: Sun Jan 25, 2004 8:57 pm    Post subject:
you are supposed to set ur hpr then set velocity thru the lpr.
View user's profile MSN Messenger
TheBush
PostPosted: Sun Jan 25, 2004 9:47 pm    Post subject:
yeah thats how your supposed to do it keep hpr around 200-220 then use lpr to set velocity Mr. Green
igjoe
PostPosted: Sun Jan 25, 2004 11:27 pm    Post subject:
Thanks for the help folks. I knew that had to be right - I just needed to hear for someone else. Very Happy
SirStunnaLot
Obi Stunn Kenobi
Obi Stunn Kenobi
PostPosted: Tue Feb 03, 2004 1:36 am    Post subject:
on a stock bko, set the hpr to 200 and adjust your fps with your lpr...
if you have upgrade valve and high flow parts.. you can lower your HPR to 180
the method is different than on the Bushmaster (which is what you were trying) due to the difference in the ram/solenoid
View user's profile Send e-mail Visit poster's website AIM Address MSN Messenger Yahoo Messenger
PostPosted: Tue Feb 03, 2004 5:51 am    Post subject:
no no no! You set the velocity w/ the LPR if you have SP mod. Otherwise the best thing to do is to set your HPR to 200, then turn your LPR up till it leaks, and then back off a whole turn, then adjust your velocity with your HPR.
SirStunnaLot
Obi Stunn Kenobi
Obi Stunn Kenobi
PostPosted: Tue Feb 03, 2004 2:24 pm    Post subject:
pat... the problem with your second method of adjusting fps with the hpr after leaking the lpr is that not all aftermarket lpr will lower the same amount of psi with your "one turn"... sp mod or not, stock or aftermarket lpr... using the lpr to adjust the fps is the most reliable method
There are a couple of extra balconies
Last post by Mmoak2018 in Buyer/Seller feedback on Dec 14, 2018 at 06:08:07
How people love MapleStory want
Last post by Mmoak2018 in Bushmaster General talk on Dec 14, 2018 at 06:06:25
70%Off Discount Michael Kors Factory Store Coupon,Orders Now
Last post by cheritys123 in Paintball talk on Nov 21, 2018 at 13:31:08
Provide Popular Mk Mi,New Products
Last post by cheritys123 in Paintball talk on Nov 21, 2018 at 13:29:21
World-Wide Michael Kors Handbags Outlet Online Canada,Divers
Last post by cheritys123 in Paintball talk on Nov 21, 2018 at 13:27:49
