Visitors: 146
Total: 146
86: Home
87: Home
97: Your Account
146: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Barb removal. :: Archived
Barb removal.
PostPosted: Thu Jun 03, 2010 5:36 pm    Post subject: Barb removal.
I need to remove a straight barb from the body of my fsp to replace it with a 90* barb. It looks like there is a little red loctite slopped around it. Normally, I would just grab a pair of vice grips, but I would think that since brass is so soft, I would just twist the brass in half.
I was thinking of just tapping an easy out into it and backing it out after warming the loctite with a hair dryer or a heat gun.
Any thoughts?
PostPosted: Fri Jun 04, 2010 3:31 am    Post subject: Re: Barb removal.
I have removed several out of PM front blocks with just a set of pliers. Try it and see, wordt case you use the ezout on what remains.
PostPosted: Fri Jun 04, 2010 8:48 am    Post subject: Re: Barb removal.
I've always used a socket to remove barbs...even ones that are locktited. WGP seemed to locktite barbs alot.
A socket will give you even force on all faces and would help to keep it from shearing off.
Good luck.
PostPosted: Sat Jun 05, 2010 1:56 am    Post subject: Re: Barb removal.
I think the barb he is reomving is one of those flush mount deals with no faces.
PostPosted: Sat Jun 05, 2010 6:22 am    Post subject: Re: Barb removal.
yup. no face. i got it out though. it is shot now though. thanks for the help.
Last post by dwn0414 in ICD Gear Forum on Nov 05, 2018 at 13:53:13
