Latest: hongwei28
Visitors: 68
Total: 68
19: Your Account
43: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Shootdown :: Archived
Shootdown
Kakeeater
PostPosted: Sat Oct 25, 2003 8:30 pm    Post subject: Shootdown
im getting shootdown at about 5 bps, how do i fix this?
Sangerpb
PostPosted: Sat Oct 25, 2003 9:38 pm    Post subject:
adjust your trigger!
ayzian
PostPosted: Sun Oct 26, 2003 6:29 am    Post subject:
??? Isn't shootdown when your shots start getting slower and slower? Smile
Anyways, if you have your stock regs, it's probably time for some lubing of the regs. Even the stock regs shouldn't suffer shootdown at 5BPS.
Use white lithium grease or DOW33 or anything without petroleum distillates and you should be fine. Use only a light coating on both your HPR and LPR.
You should be find after that.
Kakeeater
PostPosted: Sun Oct 26, 2003 8:24 am    Post subject:
thanks ayzian, but sangerpb how would my trigger affect shootdown?
Keo
PostPosted: Sun Oct 26, 2003 6:09 pm    Post subject:
it don't
dval
PostPosted: Mon Oct 27, 2003 11:31 am    Post subject:
what are regs set at?, it might be lpr is a lil high, or hpr is a lil low, shootdown occurs when you are releasing more air than you take in, so with that in mind go through the regs, and tank output, leaks may also be a factor but the first is most likely the culprit?
www.seattleseahawksteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:30:45
www.oaklandraidersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:25:49
www.lionscheapshop.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:21:15
www.tampabaybuccaneersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:16:12
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:11:34
www.sanfrancisco49ersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:07:38
www.coltscheapshop.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:03:34
www.greenbaypackersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 02:59:31
www.authenticsdetroitlions.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 02:53:53
www.officialdevils.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 02:47:43
