Visitors: 71
Total: 71
02: Your Account
22: Your Account
59: Your Account
60: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › B2K3 Problem :: Archived
B2K3 Problem
ShadowCaster
PostPosted: Sat Nov 06, 2004 7:11 pm    Post subject: B2K3 Problem
Alright, I gased the Bushmaster up today and it leaked like crazy, I shot it hoping it was just the valve and broke two balls off the bat. Don't know why, think it may important tho.
I take the barrel off, remove all the balls, and fire. The bolt moves about half an inch and does this every shot until I walk the trigger and hit about 15-16 bps, then it *pops* and then it does the little movement thing.
I have a Vaporized B2K3. HPR set at 275 and LPR is all the way in. Stock Valve. Please Help Me. TY
p8ntballfreak444
PostPosted: Sat Nov 06, 2004 7:30 pm    Post subject:
sounds like your regs need to be broken in or relubed....
also, check to make sure that the ram isnt all stickied up with junk...
PbGoods- Free paintball gear!
ShadowCaster
PostPosted: Sat Nov 06, 2004 8:31 pm    Post subject:
I checked the ram and it seemed fine no junk. Which reg should I lube and how do I do and what should I use? Can I use shocker lube?
p8ntballfreak444
PostPosted: Sun Nov 07, 2004 9:47 am    Post subject:
yes shocker lube will work.. lube both regs...
also, is the gun all stock, if not tell me what regs you have on it now..
for the hpr, you ganna want to lube the piston a little and any orings...
lpr, lube orings and piston if there is one...sry about that i havent taken my gun apart in like 6 months+ sincei havent been playing...
