Menu: |
User Info |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle bolt wont fully cycle :: Archived |
Freestyle bolt wont fully cycle Have a problem with your marker? Ask here
Go to page Previous 1, 2
View previous topic :: View next topic |
Author |
Message |
ssechriest ICDO Supporter
Posted: Tue Sep 29, 2009 11:55 am Post subject: Re: Freestyle bolt wont fully cycle |
If you want to try an HPR and see if that works. Try to lube the LP as well.
If that does not work...
I might have an extra LP I can send with the other stuff if you want to try it. I can hold off on mailing until tomorrow if you want me to look for the LPR.
Back to top |
dblk22vball ICDO Supporter
Posted: Tue Sep 29, 2009 12:00 pm Post subject: Re: Freestyle bolt wont fully cycle |
yea, I will try a different HPR tonight, I just remembered where I have another one.
I did lube and replace the o-ring in the lpr.
sure, why dont you hold off on the shipment, and I will let you know the results of the HPR swap tonight, and then if I need the lpr i can give you a heads up.
_________________ ICDO Feedback |
Back to top |
Posted: Tue Sep 29, 2009 7:50 pm Post subject: Re: Freestyle bolt wont fully cycle |
I swapped out the HPR, and the gauge was doing the same thing (slowly climbing back to pressure).
So I swapped out the lpr piston (white delrin part) with another piston I had from an old bushy (they appeared to be the same size).
The gauge was "reloading" a lot faster, but it was still not really cycling.
am i down to the solenoid being the issue?? should I take it apart to see if something is in it??
Back to top |
Posted: Wed Sep 30, 2009 9:16 pm Post subject: Re: Freestyle bolt wont fully cycle |
solved it, put the solution in the first post
Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
