Latest: NisaDisco
Overall: 7919
Visitors: 261
Total: 261
67: Home
122: Home
138: Your Account
167: Photo Gallery
193: Photo Gallery
203: Home
212: Photo Gallery
219: Photo Gallery
221: Photo Gallery
228: Photo Gallery
232: Photo Gallery
240: Photo Gallery
248: Photo Gallery
261: Your Account
Forums › General › Paintball talk :: Archives › ok, I need some help. :: Archived
BUSHWiiCK
PostPosted: Fri Jul 09, 2010 4:05 pm    Post subject: Re: ok, I need some help.
pilot 09 with eyes
Apologies. It's been a while since I've been working around Chicanos. I guess I meant to say cabron.
PostPosted: Fri Jul 09, 2010 4:13 pm    Post subject: Re: ok, I need some help.
Ok, looks like the vertical adapter is a separate piece (which you know already). It is likely attached w/ a cap head allen screw. You would likely just remove the old vertical adapter, install the new one, and then install the regulator.
I would recommend determining the proper operating pressure of the gun and then make sure the reg your purchase is capable of this pressure.
My assumption is that this gun runs at approximately 800psi since it is currently using an expansion chamber. There are not many regs out there that standardly regulate to 800psi. Most are regulating much lower and many cap out somewhere in the 300-500psi range.
If your marker operates at 800psi, you may not find any perfomance gain from simply adding a regulator. The tank regulator should do a sufficient enough job getting you consistant pressure.
Now if you are planning to change the operating pressure of the gun by changing the valve, using a lighter hammer, or any other similar thing, then secondary regulation could be helpful.
BUSHWiiCK
PostPosted: Fri Jul 09, 2010 4:18 pm    Post subject: Re: ok, I need some help.
yes i already changed my stock hammer to a ligthweight hammer and just cant keep my gun consistent. my field requires to be chrono'ed at no higher than 400 fps. my gun goes 385-400-403 and back down to 380's i figured adding a regulator and on/off asa will stop all this spiking. and im using high pressure air
PostPosted: Fri Jul 09, 2010 4:30 pm    Post subject: Re: ok, I need some help.
Yeah the regulator should help w/ spiking some. Those aren't bad spikes comsidering the general inconsistancy found in a spyder marker.
Now, I have to say, 400fps is way too high. Most sanctioned fields don't allow velocities more than 300fps and mine was 285fps. This was all due to insurance. There is no way I ever would want to get hit by a gun amped up to 400fps. Good grief!
BUSHWiiCK
PostPosted: Fri Jul 09, 2010 4:32 pm    Post subject: Re: ok, I need some help.
matterfact the max is 300 lol sorry .
EDIT* Do you know of any regs that may operate of 800 psi. im not sure how to test the psi my gun is operating on. any way?
EDIT*EDIT** Matterfact i found one and its the color i want. what do you think of this with a blue KAPP asa adapter?
PostPosted: Fri Jul 09, 2010 6:12 pm    Post subject: Re: ok, I need some help.
That one will work. Just remember that if you lightened your hammer, you have to either increase your mainspring tension or lighten your valve spring.
BUSHWiiCK
PostPosted: Fri Jul 09, 2010 7:25 pm    Post subject: Re: ok, I need some help.
yes ive bought a pack of mainsprings and i think it was the blue one that was tightest or the green one. not so sure. ^.^ but thanks 63Vdub
Nike Air Max 90 zu seiner
Last post by NisaDisco in Bushmaster General talk on Aug 08, 2020 at 07:47:37
asics scarpe basso prezzo
Last post by NisaDisco in PRP General Forum on Aug 08, 2020 at 07:43:09
basket adidas femme pas cher
Last post by NisaDisco in PRP General Forum on Aug 08, 2020 at 07:38:37
nike air max 2090 hombre
Last post by NisaDisco in Bushmaster General talk on Aug 08, 2020 at 07:34:03
