Visitors: 171
Total: 171
71: Your Account
150: Home
166: Photo Gallery
167: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › cycling problem :: Archived
cycling problem
tunainakan
PostPosted: Mon Feb 09, 2009 9:46 pm    Post subject: cycling problem
I haven't messed with my bushmaster for almost four years and now i've decided to bring it back to life. The problem im having is that when i pull and hold the trigger back the bolt stays forward. When i release the trigger is when the bolt goes back. from what i can remember this is not normal. someone please enlighten me.
howdy.
MuthaFunk
PostPosted: Mon Feb 09, 2009 11:18 pm    Post subject: Re: cycling problem
My guess is the solenoid may be sticking or dry and loosing it's seals. You might want to open up the noid and clean it out with a Q tip. Lube it with synthetic oil like gold cup and don't loose the tiny pins in the ends.
Good luck.
tunainakan
PostPosted: Tue Feb 10, 2009 12:24 am    Post subject: Re: cycling problem
i was thinking it was maybe a wiring issue because i had a loose wire and thought i found where it belonged. i dont think the noid is sticking because it clicks when the microswitch is engaged, but then makes another click noise when you dissengage from the microswitch. i would think this would all happen simultaneously when the microswitch is engaged but i dont know.
howdy.
MuthaFunk
PostPosted: Tue Feb 10, 2009 2:05 am    Post subject: Re: cycling problem
Just curious, where did the wire go back??
I think we need a little more description as to how the microswitch clicks vs the actual solenoid clicking.
Also, what is the LED light doing before, when, and after you pull the trigger? Your solenoid is currently working as though the noid is wired to the LED output on the board if it's a stock board. Confused (long shot)
As your post is writen above, it does sound like a board / wiring issue. Just need a little more info..
For your info, the icdpaintball.com website has the official bushmaster wiring drawings to download. You could cross reference your harness connections with that. Aslo, I think Madpooh has one in the sticky's here or on PBN.
tunainakan
PostPosted: Tue Feb 10, 2009 4:22 am    Post subject: Re: cycling problem
ok, when trigger is pulled the light stays off till you let go of the trigger, just like the noid, and it's a stock board. the wiring diagram i found on the nation didn't look like mine (it had pds and mine doesn't). i thought i put the loose wire back where it came from, but i guess not. it's an old bushy with the teardrops if that makes a difference.
howdy.
PostPosted: Tue Feb 10, 2009 8:35 pm    Post subject: Re: cycling problem
The microswitch could be bad...
MuthaFunk
PostPosted: Tue Feb 10, 2009 9:41 pm    Post subject: Re: cycling problem
Doublecheck your harness connections with this:
ICD Bushmaster Wiring
Let us know what you find.
***edit*** I just noticed how difficult the ICD harness drawings are to read. Let us know how it goes.
PostPosted: Tue Feb 10, 2009 9:59 pm    Post subject: Re: cycling problem
This link may be a little clearer with the the wiring diagram...
www.pbnation.com/showt...st16035779
MuthaFunk
PostPosted: Wed Feb 11, 2009 12:30 am    Post subject: Re: cycling problem
Yes that is much easier to understand. The non PDS version will have the same pinouts but with the PDS wires not there.
Last post by dwn0414 in ICD Gear Forum on Oct 16, 2018 at 01:09:34
Last post by BrandonM816 in ICD Gear Forum on Oct 12, 2018 at 18:07:19
Anybody taking ICD gun work?
Last post by etipp98 in Bushmaster General talk on Oct 12, 2018 at 05:57:20
Promaster project gun
Last post by ShottyC in ICD Gear Forum on Oct 03, 2018 at 19:59:41
Last post by Scherdy in ICD Gear Forum on Oct 02, 2018 at 22:03:50
WTB rare valves
Last post by ShottyC in ICD Gear Forum on Sep 30, 2018 at 03:48:40
2k4 Chaos Board Manual (HELP)
Last post by ShottyC in Bushmaster General talk on Sep 30, 2018 at 03:27:14
WTB LPR tester
Last post by ShottyC in ICD Gear Forum on Sep 28, 2018 at 17:36:17
All Wiring Harnesses and Marker Repairs
Last post by THE_Hulk in ICD Gear Forum on Sep 28, 2018 at 10:05:00
WTB PL Bushmaster
Last post by dwn0414 in ICD Gear Forum on Sep 24, 2018 at 03:26:40
