Latest: phalupasuan
Overall: 7907
Visitors: 96
Total: 96
01: Your Account
04: ICDU
11: Statistics
18: Your Account
22: Members List
26: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Defiant ASA stripped :: Archived
Maniac117
PostPosted: Fri May 01, 2009 1:05 am    Post subject: Defiant ASA stripped
Well, Not necessarily, but the threading in the body FOR the vertical ASA has been almost completely stripped out of the splash Defiant I recently picked up.
I'm wondering, can I get this tapped for the same ASA that a minicocker uses? It looks like it will work, but does anyone have a better idea?
hellbatman
PostPosted: Fri May 01, 2009 6:25 am    Post subject: Re: Defiant ASA stripped
I don't remember how big the hole is...provided its smaller than a 1/8NPT fitting you should be able to tap it.
I don't see the thread size on the end all be all ICD guide either...
www.icd-owners.com/htm...pic&t=7704
Maniac117
PostPosted: Fri May 01, 2009 12:53 pm    Post subject: Re: Defiant ASA stripped
Hmm.. I don't want to permanently attach it either.. I wonder if a bigger Banjo bolt would work, I'd have to drill out the original asa for that?
PostPosted: Fri May 01, 2009 3:05 pm    Post subject: Re: Defiant ASA stripped
Unfortunately no, the threading for the ASA is as large as it goes without going into the LP line that takes LP air to the manifold.
Not sure what you can do to fix that either.
veedoubleugee
PostPosted: Fri May 01, 2009 3:29 pm    Post subject: Re: Defiant ASA stripped
JB weld perhaps?
veedoubleugee
PostPosted: Fri May 01, 2009 3:30 pm    Post subject: Re: Defiant ASA stripped
or how about a threaded washer or nut at the end?
hellbatman
PostPosted: Fri May 01, 2009 4:16 pm    Post subject: Re: Defiant ASA stripped
Modify a BKO ASA to work! >.>
If I remember correctly the tray is the same size. You would need to tap the two mounting holes and possibly modify the ports...but otherwise it should work.
Maniac117
PostPosted: Fri May 01, 2009 11:26 pm    Post subject: Re: Defiant ASA stripped
I'd like to see one, if there are 2 mounting holes.
I may have to go snoop in the the guns/parts to find it in black.
I've thought about JBweld, but I'd like to retain a bit of value for it. My plan is to attempt in retaining it's appeal, fix her up, and sell it. All the guns around the house is pissing the wife off. :/
christhered
PostPosted: Sat May 02, 2009 1:41 am    Post subject: Re: Defiant ASA stripped
helicoil?
AB Freestyle Pro
Bob Long Darq Marq
Bob Long Vice
Check BST for my huge rare bushy part out sale
Maniac117
PostPosted: Sat May 02, 2009 1:45 am    Post subject: Re: Defiant ASA stripped
Hey... never thought of that. What the heck??
Would that work, having constant air pressure on it?
Last post by ViperXT in ICD Gear Forum on Apr 18, 2018 at 13:51:13
Looking for kila drive or NOX board.
Last post by ViperXT in ICD Gear Forum on Apr 14, 2018 at 12:43:16
Last post by Tzarector in ICD Gear Forum on Mar 30, 2018 at 04:05:35
Last post by Un2XS in PRP General Forum on Mar 25, 2018 at 21:32:43
WTB: Promaster
Last post by ViperXT in ICD Gear Forum on Mar 23, 2018 at 16:16:25
Last post by moodydoody in Paintball talk on Mar 22, 2018 at 07:10:48
New to B2K. Can anyone help?
Last post by moodydoody in Bushmaster General talk on Mar 22, 2018 at 02:01:52
