New Today: 1
Visitors: 242
Total: 242
67: Home
80: News
128: Home
138: Home
163: Photo Gallery
165: Photo Gallery
166: Photo Gallery
173: Photo Gallery
181: Home
192: Photo Gallery
195: Photo Gallery
213: Home
225: Photo Gallery
226: Photo Gallery
228: Photo Gallery
229: Photo Gallery
230: Photo Gallery
242: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › How do i lube the ram on the 2k3 bko? :: Archived
BkoMasta808
PostPosted: Sun Dec 07, 2003 9:46 am    Post subject: How do i lube the ram on the 2k3 bko?
i tried searching but i cant find anything on how to lube the ram on my 2k3 bko. can anyone help me? i dont know where to lube it at.
NKP82
PostPosted: Sun Dec 07, 2003 1:57 pm    Post subject:
If you want to lube the ram, you are going to have to disassemble the entire marker, I am not all the good at giving directions so some of the stuff I tell you to do might sound weird.
1.) Remove Tray
2.) [1]Unscrew the two large hex-screws that hold the ASA block to the body. [2]carefully remove ASA block, make sure not to drop or lose any of the small parts.
3.) [1] Unscrew the two hex-screws on the side of the marker. [2]Remove the Ram Assembly from the main body.
After following that procedure, put a little white lithium grease on the ram rod, the thing the Hammers is on, but you probably already know that. While you have the marker disassembled, lube the O-rings, and LPR parts that are exposed. Then to reassemble, just reverse the steps above and you are done. This does not have to be done often unless you play in areas where alot of dirt gets inside the marker, like the breach and what not. But on average you only have to do this maybe once or twice a year, well for me at least.
>12" Freak Barrel System
>14" J&J Performance Ceramic
>Dye Stickies 3
>CCM Clamping Low-rise
>AKA Sidewinder
>MacDev Red Valve
>Evlution II w/ Z Board
s0m37h1n9
PostPosted: Thu Dec 25, 2003 3:51 pm    Post subject:
I have the new 2K3 ram assembly with the screw-on cap. If I unscrew the cap and push the bolt forward, can I just put a bit of lube in there?
NKP82
PostPosted: Fri Dec 26, 2003 1:26 am    Post subject:
I am used to my old ram assembly, that was replaced with all the other 02 parts I had on it before I sent it for some repairs, so I don't know. Try your way and come back to me with your findings, if there is a now an easier way to disassembly it, I sure as hell want to know.
>Dye Stickies 3
>AKA Sidewinder
>MacDev Red Valve
TeamChaos
PostPosted: Thu Jan 15, 2004 3:50 pm    Post subject:
yeah u can i didnt and it works great but only use shocker lube or smart parts lube same thing really
s0m37h1n9
PostPosted: Fri Jan 16, 2004 7:51 am    Post subject:
@TeamChaos... were you replying to my method?
PostPosted: Fri Jan 16, 2004 2:20 pm    Post subject:
Heres a little trick i found out. to hold the ram open while you can do stuff like clean and lube the ram shaft.
WORK FOR NEW STYLE [BKO] RAMS ONLY!!
Take a piece of macroline and stick it in the ram cap part of the ram till its fully extended. Measure and cut it out so that its sticking out of the end of the ram. Stick it in and screw the ram cap back on. Screw it tight and the ram will stay open and you can clean and lube the ram to your own liking. You can also polish it a bit while its like that. Nomore constant pulling at the ram to keep it open to slab some grease on it. You can now take your time and get a nice even coat on it.
s0m37h1n9
PostPosted: Fri Jan 16, 2004 9:01 pm    Post subject:
Since we're on the topic of rams....
How do you know when there's too much pressure on the gasket between the ram and the solenoid?
PostPosted: Sat Jan 17, 2004 12:16 am    Post subject:
when the gasket gets destroyed.... Otherwise just torque it as best you can and if it doesnt move then your good. Just dont strip your screw.
s0m37h1n9
PostPosted: Sat Jan 17, 2004 7:34 am    Post subject:
Haha... it's not destroyed. But it does seem to bulge just the slightest bit where i can see it. I didn't know if because it was compressing and bulging it would be restricting airflow.
These are just some examples
