Visitors: 113
Total: 113
28: Home
89: Your Account
90: Home
102: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › eclipse hpr adjuster :: Archived
PostPosted: Wed Jun 03, 2009 3:04 pm    Post subject: eclipse hpr adjuster
i got my eclipse hpr adjuter and the stock spring does not fit. what gives?
is there a SMALLER SPRING AVAILABLE?
PostPosted: Wed Jun 03, 2009 6:25 pm    Post subject: Re: eclipse hpr adjuster
Um... Eclipse LPR adjuster?
PostPosted: Wed Jun 03, 2009 9:38 pm    Post subject: Re: eclipse hpr adjuster
it's not an LPR adjuster. I have one of those already...not the same....at least I don't think....will verify and get back to you.
PostPosted: Wed Jun 03, 2009 11:35 pm    Post subject: Re: eclipse hpr adjuster
They made both. The HPR adjuster has a larger OD on the grip part. I made the mistake of buying it thinking it would fit the LPR. Screws in fine, but when you try to put the barrel on....
PostPosted: Thu Jun 04, 2009 12:24 am    Post subject: Re: eclipse hpr adjuster
Pretty sure the LPRs and HPRs for older Bushy's use the same threading...
PostPosted: Thu Jun 04, 2009 9:56 am    Post subject: Re: eclipse hpr adjuster
yes, the threads are the same. the LP adjuster has an O-ring about half way down the threads and the HP does not. Also the knob on the HP adjuster is larger. only prob is that the HP spring in the bottom does not fit the spring seat in the eclipse adjuster. The LP spring fits in both the LP and HP adjuster seats.....seems strange. I wonder if i could use an LP adjuster spring in the HP adjuster?
anyone have an extra LP spring they don't need?
PostPosted: Thu Jun 04, 2009 8:50 pm    Post subject: Re: eclipse hpr adjuster
That is not adviseable. The difference between the two springs is why the various regs are rated as LP and HP.
PostPosted: Fri Jun 05, 2009 7:14 pm    Post subject: Re: eclipse hpr adjuster
ok...so what does one do? Is there another spring available that fits and regulates properly?
PostPosted: Mon Jun 08, 2009 9:42 am    Post subject: Re: eclipse hpr adjuster
what if I drill/mill out the Eclipse adjuster to fit the stock spring? Would that be a good soloution?
PostPosted: Tue Jun 09, 2009 9:21 am    Post subject: Re: eclipse hpr adjuster
Yes that would work just fine.
