Visitors: 125
Total: 125
30: Your Account
79: Your Account
85: Home
110: Home
112: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Bolt stick? :: Archived
Bolt stick?
bushido
PostPosted: Sun Jun 28, 2009 11:05 pm    Post subject: Bolt stick?
Ok guys I have been fighting with a 2k4 standard bushie long enough. I have lubed and replaced all the seals in it. It is bone stock except for a CP Hpr. The problem I am having is that it seems the Dwell is set to high and causing the bolt to stay forward, but with a stock board how is that possible?
Any thoughts??
PostPosted: Sun Jun 28, 2009 11:15 pm    Post subject: Re: Bolt stick?
check to see if your bolt is getting hung around the detents. Also make sure your hammer is screwed a the way on.
bushido
PostPosted: Sun Jun 28, 2009 11:18 pm    Post subject: Re: Bolt stick?
Ok I will check it out tomorrow. Thanks for the quick reply.
bushido
PostPosted: Mon Jun 29, 2009 7:54 pm    Post subject: Re: Bolt stick?
Well its not the detents or the hammer.
Hammer is screwed in all the way. and I took the detents out and it is still doing it.
PostPosted: Mon Jun 29, 2009 8:30 pm    Post subject: Re: Bolt stick?
You say the bolt stays forward? What HPR pressure are you running?
bushido
PostPosted: Wed Jul 01, 2009 12:19 am    Post subject: Re: Bolt stick?
around 250.
It cycles but sticks forward and then resets.
It has me really stumped.
MuthaFunk
PostPosted: Wed Jul 01, 2009 2:46 am    Post subject: Re: Bolt stick?
It can only be one of three things:
1.) Your bolt is hanging up on something in the breech. Check this by pulling the pin and manually running the bolt down the breech and see if there is any resistance. There should be none.
2. Your ram is binding inside. Could be a bent bolt pin throwing something out of alignment? I'm guessing you have tested your ram out by removing it form the marker, stroking it manually, and noted no problems?? Once you have the bolt out, look at the rams action when aired up and shooting. Does the hammer remain forward too long?
3. Your solenoid is sticking in the foward air position. The only way to check this is to try a different ram and see if the problem still remains. If it is the noid you can take it all apart and clean the inside. Be very careful to not loose any small parts inside. (tiny pins)
Failing any of these it might be an oddball board problem but I don't think that would be it. Also the noid coil might be getting weak, but again, I don't think that is a common problem and would be the case here.
Let us know what you find or have already found.
Always looking for better.....
PostPosted: Wed Jul 01, 2009 9:18 am    Post subject: Re: Bolt stick?
he he he....he said to stroke it manually.... Laughing
Good info Mutha.. Smile
bushido
PostPosted: Fri Jul 03, 2009 12:57 pm    Post subject: Re: Bolt stick?
Ok I went through the gun yesterday before going to the field.
The bolt is not hanging up on anything.
Swapped rams with one of my other bushies and that was not the problem.
Changed boards and it is still doing the same thing.
Swapped noids and guess what??
still didnt work!!
I have 2 other bushies here that I have swapped parts on and it just isnt worth me racking my brain over any more. I think I will keep my CP reg off it and it is time to find a new home.
Thanks guys it will be going up for trade in the BST here.
TheArtist
PostPosted: Mon Jul 06, 2009 11:20 am    Post subject: Re: Bolt stick?
check and see if the valve body is loose, also stretch the spring on the valve. Just a guess.
