Latest: Skyzhay
Overall: 7947
Visitors: 105
Total: 105
33: News
36: Home
54: Home
67: Home
77: Home
78: Home
84: Home
102: Home
103: Home
104: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle bolt wont fully cycle :: Archived
dblk22vball
PostPosted: Sun Sep 27, 2009 9:37 pm    Post subject: Freestyle bolt wont fully cycle
I am having an issue where the bolt (HE bolt kit) on my freestyle will not fully cycle.
I set the regs according to the blue fork method, and each time I pull the trigger, the bolt will move part way forward, but not back. on about the 3 rd trigger pull, the bolt will blow forward and vent air out the front of the marker.
If I then increase the lpr, the bolt will move back, but the bolt will not move forward anymore.
I have replaced all of the o-rings on the bolt, lpr and switched hpr's a couple of times. I have also lubed it with superlube oil.
I checked all of the passages and I did not see and debris.
Any ideas??
** SOLVED** Had to put a little lube on the solenoid piston itself, it ws bone dry. Works like a champ now!!
ICDO Feedback
PostPosted: Sun Sep 27, 2009 10:11 pm    Post subject: Re: Freestyle bolt wont fully cycle
Best I can say off hand is to disassemble the bolt and reassemble it per THCGunsmoke's directions. Check the Freestyle FAQ's for his website link.
He states that it the kit has to be reassmbled correctly or it will throw off the timing and that could cause that cycling issue.
After you reassemble the Bolt, reset your regs per THC's video tutorial also found on his website. Here is the link: THC reg balance tutorial
-Nick
PostPosted: Sun Sep 27, 2009 10:15 pm    Post subject: Re: Freestyle bolt wont fully cycle
Check your oring size on the stem going through the power tube. I have had issues with them before, since they can be either 006 or 007, and there are 2 common and one uncommon size for the powertube. If the oring for the powertube (the one on the outside that seals it) is midway down to the threads, you should be using the 006. Is the oring is at the top, it should be 007.
Make sure you lube the oring as well. a drop of superlube.
TheArtist
PostPosted: Mon Sep 28, 2009 5:28 pm    Post subject: Re: Freestyle bolt wont fully cycle
I have seen this even with a bad battery.
dblk22vball
PostPosted: Tue Sep 29, 2009 10:52 am    Post subject: Re: Freestyle bolt wont fully cycle
it is a number 6 on my stem.
and I am using a new battery.
The bolt moves smoothly when not in the marker, I cant think of why it wont cycle......
ICDO Feedback
PostPosted: Tue Sep 29, 2009 10:56 am    Post subject: Re: Freestyle bolt wont fully cycle
What is your high pressure?
dblk22vball
PostPosted: Tue Sep 29, 2009 11:04 am    Post subject: Re: Freestyle bolt wont fully cycle
i have tried 350-400 psi, resetting the lpr between changes.
ICDO Feedback
PostPosted: Tue Sep 29, 2009 11:19 am    Post subject: Re: Freestyle bolt wont fully cycle
You don't have another LPR to try do you?
dblk22vball
PostPosted: Tue Sep 29, 2009 11:21 am    Post subject: Re: Freestyle bolt wont fully cycle
i wish.....
ICDO Feedback
dblk22vball
PostPosted: Tue Sep 29, 2009 11:27 am    Post subject: Re: Freestyle bolt wont fully cycle
come to think of it. i was noticing that it seemed like it was taking a bit to recharge after each trigger pull, aka, when i pulled the trigger and the solenoid cycled, it took a second or 2 for the HPR gauge to rise to the proper pressure again.
hpr or lpr issue?? my guess would be hpr, but I have used it on other markers just fine...
ICDO Feedback
Blocks and steals are pretty good
Last post by Skyzhay in Freestyle General Talk on Sep 07, 2021 at 08:33:50
Madden NFL 22: Tight End Ratings
Last post by Skyzhay in Paintball talk on Sep 07, 2021 at 08:32:38
Really appreciated the group facets of dungoneering
Last post by Skyzhay in Off Topic on Sep 07, 2021 at 08:31:33
Chaussures de Nike KD
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:08:23
Converse All Star Precio
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:05:32
Nike Air Foamposite Shoes
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:02:18
Nike Air Max 1 Schoenen
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:58:34
Prodotti Adidas Nizza
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:52:24
Chaussures de Nike Air Vortex
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:47:18
Marlboro Cigarettes Online thirty minutes
Last post by sellcigarette in Paintball talk on Aug 23, 2021 at 09:36:02
