Visitors: 133
Total: 133
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle bolt wont fully cycle :: Archived
Go to page Previous  1, 2
PostPosted: Tue Sep 29, 2009 11:55 am    Post subject: Re: Freestyle bolt wont fully cycle
If you want to try an HPR and see if that works. Try to lube the LP as well.
If that does not work...
I might have an extra LP I can send with the other stuff if you want to try it. I can hold off on mailing until tomorrow if you want me to look for the LPR.
dblk22vball
PostPosted: Tue Sep 29, 2009 12:00 pm    Post subject: Re: Freestyle bolt wont fully cycle
yea, I will try a different HPR tonight, I just remembered where I have another one.
I did lube and replace the o-ring in the lpr.
sure, why dont you hold off on the shipment, and I will let you know the results of the HPR swap tonight, and then if I need the lpr i can give you a heads up.
ICDO Feedback
dblk22vball
PostPosted: Tue Sep 29, 2009 7:50 pm    Post subject: Re: Freestyle bolt wont fully cycle
I swapped out the HPR, and the gauge was doing the same thing (slowly climbing back to pressure).
So I swapped out the lpr piston (white delrin part) with another piston I had from an old bushy (they appeared to be the same size).
The gauge was "reloading" a lot faster, but it was still not really cycling.
am i down to the solenoid being the issue?? should I take it apart to see if something is in it??
ICDO Feedback
dblk22vball
PostPosted: Wed Sep 30, 2009 9:16 pm    Post subject: Re: Freestyle bolt wont fully cycle
solved it, put the solution in the first post
ICDO Feedback
Page 2 of 2
