Visitors: 65
Total: 65
21: Your Account
53: Your Account
Forums › General › Paintball talk :: Archives › Proto SLG UL :: Archived
Proto SLG UL
PostPosted: Thu Oct 15, 2009 6:52 pm    Post subject: Proto SLG UL
i got my new proto slg ul coming in tomm and was wondering if anyone knows if theres anything i should do with it before playing?..thanks
PostPosted: Fri Oct 16, 2009 2:10 am    Post subject: Re: Proto SLG UL
Get a good battery. Remember that the regulator holds pressure so bleed it off using the back cap after you take your tank off. Lube it after every day of play (just the O-ring on the funny hourglass piece). Tighten the screw that holds the ASA rail in place (take the grip panel off to do it). Don't mess with the dwell, it won't increase your efficiency at all. Remember the more you **** around with a marker the less reliable it will be. Enjoy.
P.S. I haven't messed with my '09 SLG UL at all and the only problem I have had was a little bit of a loose ASA and a dead battery.
PostPosted: Fri Oct 16, 2009 8:45 am    Post subject: Re: Proto SLG UL
thanks spitle..i just hope that mine isnt one of the ones that i heard of people having to send theres into dye for a new bolt
PostPosted: Fri Oct 16, 2009 10:12 am    Post subject: Re: Proto SLG UL
i have a PMR and so far it has been about the most reliable gun I own. It holds air too, but acouple dry fires and it empties.
PostPosted: Sat Oct 17, 2009 1:27 am    Post subject: Re: Proto SLG UL
The '08s needed new bolts. Mine did, but they just monkeyed with the marker instead of fixing it. Finally after three times into Dye for repairs and one nasty letter from Mike @ TechPB they just gave me a brand new '09 SLG UL.
PostPosted: Sat Oct 17, 2009 11:32 am    Post subject: Re: Proto SLG UL
niice..yeah..im trying it out tomm!..hope it works lol
PostPosted: Sun Oct 18, 2009 12:37 am    Post subject: Re: Proto SLG UL
I hope it works well for you.
PostPosted: Sun Oct 18, 2009 8:49 pm    Post subject: Re: Proto SLG UL
well just got back and did some one on ones with my friend and this gun is like a dream lol
PostPosted: Tue Oct 20, 2009 12:40 am    Post subject: Re: Proto SLG UL
Cool, I am glad you like it.
