Visitors: 70
Total: 70
21: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › BKO problem. HELP! :: Archived
BKO problem. HELP!
mgfcommand
PostPosted: Sun Nov 15, 2009 5:27 pm    Post subject: BKO problem. HELP!
Hello,
My BKO 2k4 has got a problem. I gas up and turn the gun on, and when I pull the trigger I hear the noid click but nothing else happens. I'm getting enough pressure on the gauge on the hpr. I changed the battery 3 times. I disassembled, cleaned and lubed the lpr, valve, bolt, the rear portion(manifold?) of the solenoid and nothing has worked. I lubed and checked the hammer, it doesn't appear to have a problem. I adjusted the lpr reg to the point where the noid leaks , so I believe there is no issue with pressure there. The board has no visible damage, the wire connections appear to be fine. The LED lights up and flashes with each trigger pull.
I'm out of ideas, maybe replace the entire solenoid? But if thats the case, is it even worth it? my BKO is basically all stock except for the bolt
Thanks for your thoughts, I found the info on this board realy helpful
PostPosted: Tue Nov 17, 2009 3:07 pm    Post subject: Re: BKO problem. HELP!
When you air up your BKO, try pushing on the little button at the top of the solenoid to see if it will manually cycle.
