Latest: dm822d5x
Overall: 7932
Visitors: 235
Total: 235
26: Your Account
103: Home
104: Your Account
106: Home
129: Home
156: Photo Gallery
192: Photo Gallery
193: Photo Gallery
195: Photo Gallery
209: Photo Gallery
214: Photo Gallery
223: Home
234: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › Velocity Control :: Archived
Velocity Control
igjoe
PostPosted: Sun Jan 25, 2004 8:28 pm    Post subject: Velocity Control
I've set my HPR to 200psi, I've backed my micro rock LPR off and slowly adjusted it in until it cycles then gave it a 1/4 - 1/2 turn. I fire a shot and the ball pops out about 5 feet (no chrono reading). I then slowly start to increase the inline reg to increase velocity. I've cranked that sucker up as high as 450psi and I can't get anything higher than 175fps. What gives?
I've noticed that if I keep my HPR at 200psi and start to crank up the LPR I get velocity setting as high as 300fps.
What should I do or what am I doing wrong? Question
lil_tyrant
PostPosted: Sun Jan 25, 2004 8:57 pm    Post subject:
you are supposed to set ur hpr then set velocity thru the lpr.
TheBush
PostPosted: Sun Jan 25, 2004 9:47 pm    Post subject:
yeah thats how your supposed to do it keep hpr around 200-220 then use lpr to set velocity Mr. Green
igjoe
PostPosted: Sun Jan 25, 2004 11:27 pm    Post subject:
Thanks for the help folks. I knew that had to be right - I just needed to hear for someone else. Very Happy
SirStunnaLot
Obi Stunn Kenobi
Obi Stunn Kenobi
PostPosted: Tue Feb 03, 2004 1:36 am    Post subject:
on a stock bko, set the hpr to 200 and adjust your fps with your lpr...
if you have upgrade valve and high flow parts.. you can lower your HPR to 180
the method is different than on the Bushmaster (which is what you were trying) due to the difference in the ram/solenoid
View user's profile Send e-mail Visit poster's website AIM Address MSN Messenger Yahoo Messenger
PostPosted: Tue Feb 03, 2004 5:51 am    Post subject:
no no no! You set the velocity w/ the LPR if you have SP mod. Otherwise the best thing to do is to set your HPR to 200, then turn your LPR up till it leaks, and then back off a whole turn, then adjust your velocity with your HPR.
SirStunnaLot
Obi Stunn Kenobi
Obi Stunn Kenobi
PostPosted: Tue Feb 03, 2004 2:24 pm    Post subject:
pat... the problem with your second method of adjusting fps with the hpr after leaking the lpr is that not all aftermarket lpr will lower the same amount of psi with your "one turn"... sp mod or not, stock or aftermarket lpr... using the lpr to adjust the fps is the most reliable method
nike air max 95 grey/brown
Last post by dm822d5x in Paintball talk on Feb 07, 2021 at 02:59:47
nike air force 1 shadow femme
Last post by zspgrons in Freestyle General Talk on Feb 02, 2021 at 06:49:04
nike air force 1 shadow blau
Last post by zspgrons in Paintball talk on Feb 02, 2021 at 06:45:15
Last post by maloneoni in Calendar of Events on Jan 25, 2021 at 03:02:04
