Visitors: 84
Total: 84
Forums › Buy/Sell/Trade › ICD Gear Forum :: Archives › Manifold for 04 Freestyle Needed :: Archived
ray2703
PostPosted: Wed Feb 03, 2010 4:47 pm    Post subject: Manifold for 04 Freestyle Needed
i have a leak somewhere from my manifold and i have tried to find one but cant. i have seen pics of some manifolds with blue hoses with different barbs? my fs has a clear hose like you would see on a cocker 3-way which i think is a different barb?
DonF
PostPosted: Wed Feb 03, 2010 7:20 pm    Post subject: Re: Manifold for 04 Freestyle Needed
The clear hose always leaked on me = are you sure thats not your leak?
If you manifold pulled it threads then you can try longer screws -> see my thread. If they are pulled completely out then you will need to tap and drill.
You sure your regs are ok? It could it just be the noid venting. I got a cheap fs and the guy just lost a spring in the lpr. Then he stripped the manifold because he thought the venting noid was a leak!
I always take that stuff apart for a look see
ray2703
PostPosted: Wed Feb 03, 2010 7:52 pm    Post subject: Re: Manifold for 04 Freestyle Needed
well it was my old gun and i needed the money so i sold it off. the kid went to air it up and it leaked been sittin for a year or two so i wasnt concerned. the guy at the pb shop played with the regs and adjusted them to "where they need to be". i was called up to see if i could figure it out and its definately comin from the gasket but with the good ol spit test you can see bubbles comin from the barb and hose that connects to the manifold as well??? i didnt have much time to play with it but i narrowed it down and now im coachin the guy through the entire process. it could be the lpr set to high but i dont have the marker to tinker on
DonF
PostPosted: Wed Feb 03, 2010 8:51 pm    Post subject: Re: Manifold for 04 Freestyle Needed
I got some black hi pressure hose from palmer. The clear stuff always leaked on me sooner or later. The black stuff is really hard to get on but it never leaks!
ray2703
PostPosted: Wed Feb 03, 2010 9:06 pm    Post subject: Re: Manifold for 04 Freestyle Needed
i could try that, palmer the only place that carries it?
DonF
PostPosted: Wed Feb 03, 2010 9:49 pm    Post subject: Re: Manifold for 04 Freestyle Needed
You paintball store should too right? I have some but it would probably be just as fast to order it from palmer.
ray2703
PostPosted: Thu Feb 04, 2010 12:56 am    Post subject: Re: Manifold for 04 Freestyle Needed
i never use the store he did its an hour drive. we had our own local store which went out of business which snow balled into me gettin out of paintball for the time being. i think we got most of the leaks figured out and are just waitin on the new noid gasket
