Visitors: 63
Total: 63
28: Home
56: Your Account
Forums › General › Paintball talk :: Archives › So, I got this box in the mail... :: Archived
Go to page Previous  1, 2, 3, 4, 5  Next
pump
I like bukkake!
I like bukkake!
PostPosted: Wed May 26, 2010 7:26 am    Post subject: Re: So, I got this box in the mail...
yeah thats right my friends did an mq excal, but they dont count theres three tubes on that thing
and that mac is badass why not make a delrin piston for it?
i dont think they make straight ones, but ou could just bend the hoses or some can use barbs and just put on a elbow instead
thinking that your bolt and piston will have less total mass that an excal(or any other poppet) with the ram, pull pin, bolt, and the rams pull pin attachment part. so you might get more cps for the same LPR psi as other guns....well depending on the hoses, you might also stick the noid up into the bottom tube closer to the ram.
autotriggers for sale
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Wed May 26, 2010 10:22 pm    Post subject: Re: So, I got this box in the mail...
well, i've got the board poked up in there currently. i'm a little hesitant about trying to make a delring piston for the MAC, it's pretty thin, and my overall weight savings would be minimal. having some issues uncapping my rate of fire with the eyes disabled. I think i need to talk to Damon...
pump
I like bukkake!
I like bukkake!
PostPosted: Wed May 26, 2010 10:32 pm    Post subject: Re: So, I got this box in the mail...
true that, thats not much weight either, which is AWESOME!!!!!!
im curious to know now how fast a ram can cycle with long air lines, i think im gonna try and figure that out
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Sun May 30, 2010 10:06 pm    Post subject: Re: So, I got this box in the mail...
www.youtube.com/watch?v=oKo2RfTc0RU
more to come.
PostPosted: Mon May 31, 2010 12:03 am    Post subject: Re: So, I got this box in the mail...
Love it other than the creeking of the camera moving lol....
pump
I like bukkake!
I like bukkake!
PostPosted: Mon May 31, 2010 8:58 am    Post subject: Re: So, I got this box in the mail...
whatever i love the creaking and the Wayne's World Extreme Close-Up oh and 90* angle shooting
its my favorite bad video ever
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Mon May 31, 2010 9:49 am    Post subject: Re: So, I got this box in the mail...
Very cool. Keep those videos coming.
PostPosted: Mon May 31, 2010 11:18 am    Post subject: Re: So, I got this box in the mail...
Swapped to a dyn ram and started getting a lot faster cycles. Tried the GBR, and was still getting full cycles at lower dwells than the MAC. Gonna have to get with cs900 about making a delrin shaft for it.
pump
I like bukkake!
I like bukkake!
PostPosted: Tue Jun 01, 2010 7:32 am    Post subject: Re: So, I got this box in the mail...
take out one of the pinching orings from the GBR you might get a lot more cps
also your settings might just be the thing holding it back, check to see that they are tuned
i think the weight of your metal shaft(bow chica bow wow) with the bolt is light enough
also AcidCustoms might still have delrin shafts with metal middles
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Tue Jun 01, 2010 5:50 pm    Post subject: Re: So, I got this box in the mail...
Well, with the default settings on the tboard (dwell=5 CON = 60 CDEL= 10 COFF = 10). I couldn't get any ram to feed. I had to bump CON up to 100 to get the mac to feed consistently. I went through 136ci of air dinking with all the settings one at a time to find that out. I didn't swap rams until my last 500 lbs of air, and lo and behold, the ported dyn ram gave me consistent feeds at 65 on the CON. The GBR looked and sounded to be cycling fully at those settings as well.
On a better note, if I dissasemble pm QEVs, I can fit them and then put them back together once they are threaded in. I know that will help since I am feeing the ram through about 2 1/2" of hose on either side...
Page 4 of 5
