Visitors: 163
Total: 163
103: Home
127: Home
143: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Leak problem Promaster. Please identify my board/chip :: Archived
ojjak
PostPosted: Sun May 30, 2010 4:24 pm    Post subject: Leak problem Promaster. Please identify my board/chip
Hi.
My english isnt 100% but i will try to explain my best.
I have 2 problems.
Today i was shooting with my gun. The gun hasnt been fired since a year back.
I found different leaks but after a dissambly and oring change all leaks was gone except one.
This "valve?" is leaking. There is a type of gasket inside but it looks ok.
I took my gun to a instrument to measure the speed per second i was fireing. I got to 200-240. But after 240 it started to leak really much.
The other problem is that i dont know what board i have in my Promaster.
It looks like this
The only thing i remember about the board is that the first switch is fireing mode. The second and third one is dwell or debounce and the fourth is BPS
Best regards Nicklas
PostPosted: Sun May 30, 2010 5:11 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
Nicklas, what is leaking is your QEV or quick exhaust valve. is it leaking where it threads into the marker or from the mall hole at the rear?
Your board is a stock Promaster board, and the manual for it can be found here:
www.icd-owners.com/fil...Manual.pdf
ojjak
PostPosted: Mon May 31, 2010 12:11 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
Thank you for the answer. Its leaking from the rear hole.The ICD manual says that if the QEV is leaking, replace it.
I used google a little bit, and i saw on one page that the ION Qev fits the promaster?
No, i dont think that it is the standard promaster board. This is the settings:
First you turn the gun off. And flip the choosed dipswitch over and Pull the trigger for specific mode. When finished pull the switch back and restart the gun.
1.Fire mode. 1 Click on the trigger when the switch number 1 is on means manual mode, 2 clicks Ramp setting 3 clicks another ramp and 4 clicks Full auto
2. The second switch is either Dwell or bebounce
3. Same as number 2
4. This setting is BPS, 30 clicks for 30bps and 10 for 10bps.
I hope you understand what i mean.
/Nicklas
PostPosted: Mon May 31, 2010 3:48 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
Sorry about that, looks like you have the Lasoya board, and that manual can be found here:
www.icdproducts.com/pa...ttings.pdf
I don't know that the ION QEV fits, but I am pretty sure that any cocker QEV will work, and www.airsoldier.com has them in stock.
ojjak
PostPosted: Mon May 31, 2010 6:15 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
Hello.
I have bought a new QEV.
No, its not that board either Sad The board must be very rare. The only thing i remember was "Croc" or something :S
PostPosted: Mon May 31, 2010 8:07 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
could it be a kila board?
kila manual
i dont know of many more that have dip switches.
PostPosted: Mon May 31, 2010 8:25 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
I don't know why i did not think of the Kila board. Hope that helps.
PostPosted: Mon May 31, 2010 9:01 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
My kila board is red, not green....
PostPosted: Mon May 31, 2010 11:18 pm    Post subject: Re: Leak problem Promaster. Please identify my board/chip
hm, must not be a kila board.
