Visitors: 57
Total: 57
09: Home
33: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Crammer stuck forward when aired up. :: Archived
Chace365
PostPosted: Sat Aug 14, 2010 3:56 pm    Post subject: Crammer stuck forward when aired up.
Alright, I got my crammer to stop leaking. Now, it won't cycle properly.
It's stuck forward when it's aired up. Any idea as to why?
When I pull the trigger to fire, it just puffs and moves back a little, but nothing other than that.
Need a King Smurf Crammer!
PostPosted: Mon Aug 16, 2010 2:52 pm    Post subject: Re: Crammer stuck forward when aired up.
somebody once told me it was a solenoid issue. Weak return spring or something.
PostPosted: Mon Aug 16, 2010 3:11 pm    Post subject: Re: Crammer stuck forward when aired up.
Stuck FORWARD when aired?? Does it come back if you pull the bolt pin? It might be that the air lines are reversed??
When it "puffs", the solenoid is not completely cycling. I have had this problem with multiple noids where the u-cup seals inside are packed with lube. After cleaning and wiping out as much lube as possible, I usually get them working again in the first try. Not always but usually. could also be the piston is stuck. Do you use dow 33 or some other grease-type lube?
Chace365
PostPosted: Mon Aug 16, 2010 4:11 pm    Post subject: Re: Crammer stuck forward when aired up.
I PM'D Spitle over on TechPB and the air lines are reversed.
PostPosted: Tue Aug 17, 2010 9:42 am    Post subject: Re: Crammer stuck forward when aired up.
On bushies with the parker noids I discovered this. Pull the return spring out and stretch it a bit and it is fixed.
looks like he posted this in the wrong forum...he's got a promaster I guess....cuz we all know bushies don't have hoses....yuck. Smile
