Latest: major_movit
Overall: 7915
Visitors: 43
Total: 43
Forums › Marker Talk › Problem/Tech forum :: Archives › Bushmaster Manifold O-ring Question :: Archived
pump
I like bukkake!
I like bukkake!
PostPosted: Wed Aug 18, 2010 10:19 am    Post subject: Re: Bushmaster Manifold O-ring Question
wow you changed everything....and the leak still comes from that smaller notch?
is the gasket getting smashed? noid on manifold too tight?
is the body burred allowing air to pass the manifold orings?
and what is UR?
Hawaiipb.com Hawaii's Paintball forum
autotriggers for sale
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Wed Aug 18, 2010 10:20 am    Post subject: Re: Bushmaster Manifold O-ring Question
i had this problem on my Bonebrake. Venting out the little relief cutout on the manifold. what Noid do you have, parker or humphrey? I'm betting humphrey.
dblk22vball
PostPosted: Wed Aug 18, 2010 10:24 am    Post subject: Re: Bushmaster Manifold O-ring Question
ur = urethane, aka the white/clear hard o-ring
When I initially took my manifold off, the UR o-ring, which is the center seal, in the middle of the really large circle o-ring, was ripped, partially blocking the hole so it would not shoot past 150 fps. That is what started this adventure.
I replaced the UR90 o-ring with a standard black buna-70 o-ring.
ICDO Feedback
dblk22vball
PostPosted: Wed Aug 18, 2010 10:25 am    Post subject: Re: Bushmaster Manifold O-ring Question
humphrey. and I have tried 2 of them Sad
ICDO Feedback
pump
I like bukkake!
I like bukkake!
PostPosted: Wed Aug 18, 2010 10:26 am    Post subject: Re: Bushmaster Manifold O-ring Question
darn so it is the durometer
sorry for the wild goose chase
Shocktech B2Ks
NIB Warp Feeds FS
dblk22vball
PostPosted: Wed Aug 18, 2010 10:30 am    Post subject: Re: Bushmaster Manifold O-ring Question
yea, I am thinking I need to track down a UR or buna 90 duro o-ring.
my hardware store only carries 70 duro unfortunately and I dont really feel like paying $15 to get 100 of them from mcmaster-carr.
ICDO Feedback
pump
I like bukkake!
I like bukkake!
PostPosted: Wed Aug 18, 2010 10:35 am    Post subject: Re: Bushmaster Manifold O-ring Question
i hear that i been looking for cheep rings for a while...u cups especially
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Wed Aug 18, 2010 3:05 pm    Post subject: Re: Bushmaster Manifold O-ring Question
yes, my experience with this problem is the center o-ring. needs to be a harder urethane oring. the pressure is just too much for the softer ones. it's leaking past the center oring and venting through that side hole. this was my experience too...tried everything kept venting, then changed manifolds and to the urethane oring at the same time...problem gone. there is a reason they went to the urethane orings on those manifolds. I suspect the softer ones compress too much and might possibly even buckle or distort a tad and comprimise the seal. the drag is that most aftermarket bushy o-ring kits do not come with the proper urethane ring... might be able to order a handful from oringguy.
pump
I like bukkake!
I like bukkake!
PostPosted: Wed Aug 18, 2010 9:12 pm    Post subject: Re: Bushmaster Manifold O-ring Question
what size do you need for it?
what durometer?
what durometer is BunaN?
Shocktech B2Ks
NIB Warp Feeds FS
dblk22vball
PostPosted: Tue Aug 31, 2010 10:16 am    Post subject: Re: Bushmaster Manifold O-ring Question
ok, so an update for everyone: I got a 010 90 duro o-ring and it seems to have stopped my leak.
However, now when I air up the marker, the solenoid seems to vent the HPR air off until the reg reaches roughly 140 PSI.
So I will set the reg at around 180-190 PSI, set the LPR and then fire a shot. The marker will fire as it should, but then when it recharges for the next shot, you can hear (and feel) the solenoid venting some air and the HPR gauge drops to 140 PSI. You see the HPR jump back up to 200 briefly, and then it drops to 140.
Anyone seen this before?
ICDO Feedback
