New Yesterday: 1
Visitors: 211
Total: 211
46: Home
86: Home
150: Home
157: Photo Gallery
168: Photo Gallery
180: Home
182: Photo Gallery
184: Photo Gallery
189: Home
198: Photo Gallery
209: Photo Gallery
210: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › |34|) FSDO :: Archived
|34|) FSDO
soap_shoes
PostPosted: Mon Feb 16, 2004 1:20 pm    Post subject: |34|) FSDO
hey
ok yesterday i was outside shooting my bko, and i knew this was going to happen because it always does; i wait for like a minute after shooting to shoot again and the paint either goes 5 feet or gets stuck in the choke points in the barrel. i triple fed once, and i have the macroline detent....
i also have a male palmers stabe and anti-siphon co2....but it cant be the co2, because if i dont wait too long to shoot, it goes full distance...
help plz!
max
View user's profile Send e-mail AIM Address MSN Messenger Yahoo Messenger
soap_shoes
PostPosted: Mon Feb 16, 2004 1:22 pm    Post subject:
oh yea, im using a gravity fed hopper, and im getting an egg by the end of this week, but then again that would only explain 3/4 of my chops......definitely not FSDO......
thx
max
soap_shoes
PostPosted: Mon Feb 16, 2004 1:35 pm    Post subject:
ALSO, 8), i just tested for blowback while dryfireing with a business card on top. nothing. the card just moved a bit from the recoil...
thats how u test for it rite!?!?/!?
KrazyGnome84
PostPosted: Mon Feb 16, 2004 3:04 pm    Post subject:
u put two balls in your stack and then put the creditcard ontop and if it flys off its cuz the other ball knocked it off and you have blow back.
soap_shoes
PostPosted: Mon Feb 16, 2004 4:06 pm    Post subject:
well i shot all of my balls yesterday dammit lol
any suggestions to the fix!?!?
Doc
PostPosted: Mon Feb 16, 2004 9:36 pm    Post subject:
No. That only shows bolt bounce.
Put one paintball in the receiver. Then follow the rest of the instructions. The reason for the one paintball is to provide resistence to the outgoing air.
If you put more than one paintball in, the next one in line get's bounced upwards as the bolt moves forward; the diameter of the bolt is larger than the diameter of the paintball, therefore the lip on the bolt will catch the bottom of the next paintball in the stack causing it to bounce upwards.... thus "bolt bounce".
Cheers
Lion's Pride www.lionspridepaintball.com
CPPA #1278
B2K4 PDS, Vapor Valve, AKA Sidewinder, AKA SCM 3, 2k7 Chaos
2k3 Black BKO, Modified stock Valve, AKA Mitey Max, Zenitram BKO ASA adaptor, Palmer Stabilizer/Micro-rock, 2k4 Chaos
06 SGM WRX Wagon
Stark
PostPosted: Tue Feb 17, 2004 3:31 am    Post subject:
Dunno why this thread is talking about blow back when the title says FSDO Very Happy
Anyway, FSDO can be caused by slow leaks, or a sticky piston in your reg. Make sure your reg is clean and lubed, check all your seals and O rings for damage - replace if they look sickly. After doing that and your still getting FSDO it may be a leaking valve seal, are you running a stock valve or after market?
I can´t think of anything witty right now
soap_shoes
PostPosted: Tue Feb 17, 2004 2:25 pm    Post subject:
aftermarket, palmers stabalizer.....which brings me to my next question.
how do i care for it? i mean, the manual says that once its set you wont have to adjust it again.....
ive never lubed it or anything, but since i got it, ive had fsdo, and i cant check to see if its the reg cuz since im using co2, i cant put the stock reg back in.........
so does anyone know how to take apart/lube the stabe??
thx,
max
soap_shoes
PostPosted: Tue Feb 17, 2004 2:27 pm    Post subject:
wait......having an aftermarket reg w/o an aftermarket valve wont starve my marker, will it?? Confused
polemos
PostPosted: Thu Feb 19, 2004 5:44 am    Post subject:
The Palmer Stabilizer - $6 to Palmer pursuit if you are concerned about your regulator. Palmer will check it out for you.
Your lack of an aftermarket valve is not the issue.
FSDO - LPR leaking, hammer shaft sticking, are 2 of the possible issues.
These are just some examples
