Visitors: 64
Total: 64
15: Your Account
21: Home
Forums › General › Paintball talk :: Archives › Sypders :: Archived
Sypders
Go to page 1, 2, 3, 4, 5  Next
PostPosted: Fri Jan 14, 2011 12:38 am    Post subject: Sypders
Does anyone know the older ones? I have one I found in my brother's closet that needs a little tlc. I think the board is fried.
PostPosted: Fri Jan 14, 2011 12:45 am    Post subject: Re: Sypders
once the boards fry, they're toast, from what iv'e found. I could never fix mine. Maybe a new capacitor is what was needed, I dunno.
PostPosted: Fri Jan 14, 2011 12:48 am    Post subject: Re: Sypders
I was hoping to drop a new board into it.
Actionvillage has a sypder pilot/electra board for 7.00 dollars. I think the electra came out about the same time. Do you think they are interchangeable?
PostPosted: Fri Jan 14, 2011 12:57 am    Post subject: Re: Sypders
they should all fit with eachother, assuming that the boards match. I think they change them a bit a few years back, but i could be wrong.
PostPosted: Fri Jan 14, 2011 12:58 am    Post subject: Re: Sypders
The only difference I can see is that this board uses two buttons instead of one, but I can drill another hole in the trigger frame.
PostPosted: Fri Jan 14, 2011 12:59 am    Post subject: Re: Sypders
www.actionvillage.com/011-462-0010
That is the board I am looking at.
PostPosted: Fri Jan 14, 2011 1:08 am    Post subject: Re: Sypders
wow that IS cheap.
i'm sure you can make something work. in fact, i'm getting one two. we can work on this together; i've always wanted to get my spyder working again.
PostPosted: Fri Jan 14, 2011 1:12 am    Post subject: Re: Sypders
There is not much to lose by ordering that board. I don't even know why I am bothering doing some research on it. Habit, I guess.
I would think it is just a Sypder, but last time some approached me to help them get their BNIB spyder working, I had no idea how to adjust the velocity on it.
PostPosted: Fri Jan 14, 2011 1:24 am    Post subject: Re: Sypders
just like an autococker, there's a screw on the back that changes the spring tension.
PostPosted: Fri Jan 14, 2011 1:25 am    Post subject: Re: Sypders
That is what I was looking for, but I could not find that screw. I am sure I could have figured it out, but it was an evening at SCP and I only had a couple of hours to play.
Page 1 of 5
