Visitors: 59
Total: 59
Forums › Marker Talk › Problem/Tech forum :: Archives › |34|) FSDO :: Archived
|34|) FSDO
Madpooh
PostPosted: Thu Feb 19, 2004 8:39 am    Post subject:
don't get the egg
www.geocities.com/icdo58/index.htm
BKO and
Bushmaster Repair Shop and PDS Installation Upgrade
Affordable services.  Why pay more?
soap_shoes
PostPosted: Thu Feb 19, 2004 2:20 pm    Post subject:
1) y not the egg
and
2) could the fsdo be caused by my hpr set too high? last time i saw it, it was at 300, then i screwed with it cuz my gauge is broken, and my new gauge should be coming in.....
so that brings me to my new question:
is the screw at the bottom of the palmers stab. screwed out for lower pressure or in for lower pressure?
i need to know a.s.a.p.!!
thx
max
View user's profile Send e-mail AIM Address MSN Messenger Yahoo Messenger
madgoat33
PostPosted: Thu Feb 19, 2004 3:07 pm    Post subject:
KrazyGnome84 wrote:
u put two balls in your stack and then put the creditcard ontop and if it flys off its cuz the other ball knocked it off and you have blow back.
No, because that could happen from ball bobble, u just use a business/credit card because if theres enough blowback to move a ball, there would be enuff you move a business card.
soap_shoes
PostPosted: Thu Feb 19, 2004 5:42 pm    Post subject:
no, the air shoots out the barrel and is never directed to the feed tube then Laughing
soap_shoes
PostPosted: Thu Feb 19, 2004 5:46 pm    Post subject:
O MAN....i just got my gauge today, and as i was unscrewing the old broken one, the head of the gauge came off! so i just twisted it so the copper would break.......luckily i had a spot for a gauge in my stabe, so i put it in there......gassed it up...
PPPPPPPSSSSHHHHHHHH, right where the copper wire poked out; apparently the wire was hollow for air to get thru. just great. so now, i have a leak i cant get rid of unless i pinch the hole with vice grips or put some glue on the tip......
why the %^&* does icd make their gauge thread bigger? how dumb! now my gun looks ghetto.....from the left side Cool
does anyone know where to buy a gauge that would fit it?? i mailed icd about it but i doubt they would send me one cuz im using co2.....actually im using n2 Cool ....
thx
rguerz
PostPosted: Fri Feb 20, 2004 9:53 pm    Post subject:
the gauge should be all standard sizes. You should be able to take the old gauge off and either put you new gauge there or the screw that was used to block the hole in the new reg.
soap_shoes
PostPosted: Sat Feb 21, 2004 12:08 am    Post subject:
but if the screw was in the reg, and thats where my new gauge is cuz it didnt fit in the normal spot, the screw thing wouldnt fit either. and i dont know if i can get my screw out, since the head popped off, theres no way to unscrew it.....:(
should i get a new asa? zenitram? if so will i need like a new lpr and something else to go into the other hole so it doesnt leak? so wut would i need if i got the zenitram??
thx again,
max
Ricky
PostPosted: Sat Feb 21, 2004 11:54 am    Post subject:
what do u mean what would u need. the zenitram would simply replace your stock ASA. Just put everything back onto that.
soap_shoes
PostPosted: Sat Feb 21, 2004 11:57 am    Post subject:
d000000d,
if u've read any of this, you wouldknow that the micro gauge that goes into the icd asa is larger than the standard size....
is the gauge hole in the zenitram the size of an icd gauge or a standard sized gauge?
soap_shoes
PostPosted: Sat Feb 21, 2004 1:13 pm    Post subject:
ok, i had put loctite on the leak point like 2 hrs ago....i gassed it up...no leak! www00000000ttttt Cool
now i just gotta save for the zenitram asa, barb kit, and micro rock Laughing
anyone know where i cud buy that stuff in a package for cheep cheep? Confused
Page 2 of 3
