Visitors: 112
Total: 112
33: Your Account
76: Your Account
77: Home
Forums › General › Paintball talk :: Archives › Sypders :: Archived
Sypders
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jan 14, 2011 4:59 am    Post subject: Re: Sypders
a 7 3/4 inch braided wire
an offset duckbill with standard threads
a barrel( i forgot i sold mine)
and an expansion chamber.
For a grand total of around $22 shipped if i'm not mistaken, perhaps a bit more.
PostPosted: Fri Jan 14, 2011 5:14 am    Post subject: Re: Sypders
That's the capacitor that you need to run the pancake solenoid. It sits there and holds enough charge to trip it.
Oh, so that wouldn't work so well in a mech>electro build. Geez, I didn't even know those electro Spyders had noid's in them. I had taken apart a Viewloader EMX-1000 one time and it had a big metal cylinder in a similar location to that capacitor. I thought the cylinder had something to do with catching and releasing the ram/hammer/whatever, but that was a while ago. It did have those two buttons on the back of the grip located in the same place as that Tadao board, so I thought it might be interchangeable.
PostPosted: Fri Jan 14, 2011 5:29 am    Post subject: Re: Sypders
There's a good chance that' what it was, the operate nearly the exact same way as a spyder; just some different placement inside the grips.
PostPosted: Mon Jan 17, 2011 9:13 pm    Post subject: Re: Sypders
Got the board today. To start with, this appears to be the VS board, which may cause problems...
www.spyder.tv/section/..._board.pdf
The battery connection is backwards. I will have to flip the wires in the connector.
The switch connector has three prongs, and my marker has two, I'm not certian how to fix that issue yet. It seems the top prong does nothing. if i connect the two lower prongs, the solenoid will trip. I found out i can still stuff the switch connector on the bottom two and it will both stay in place as well as fire; great success!
PostPosted: Tue Jan 18, 2011 12:01 am    Post subject: Re: Sypders
poop. I am glad I held off then. AV really should have put that in the listing.
I should probably just look around for a part out on pbn.
PostPosted: Tue Jan 18, 2011 12:23 am    Post subject: Re: Sypders
but good news. it's working as far as i know. I gotta find where all my screws went off to, then air it up and see what happens.
PostPosted: Tue Jan 18, 2011 6:18 pm    Post subject: Re: Sypders
damn, if i had read this post about spyders, i would have given you the SS line, for shipping Martix. i have all new lines that i am keeping for whatever reason. guess, i'll take some pics and put it in my on going sale threads.
PostPosted: Thu Jul 07, 2011 5:03 pm    Post subject: Re: Sypders
Hehehe, thought this was appropriate.
PostPosted: Thu Jul 07, 2011 5:11 pm    Post subject: Re: Sypders
huh?
PostPosted: Thu Jul 07, 2011 5:13 pm    Post subject: Re: Sypders
vs2 thread...
Facepalm...
Page 4 of 5
