Visitors: 57
Total: 57
Forums › General › Paintball talk :: Archives › My Lasoya ProMaster won't pressurize... :: Archived
PBpancake
PostPosted: Sat Mar 19, 2011 10:01 pm    Post subject: My Lasoya ProMaster won't pressurize...
Yet again, another problem with my Lasoya ProMaster.
I air it up, but nothing happens. The bolt doesn't go back, the gauge doesn't move, nothing. All that happens is the solenoid clicks. I have verified that there is a small leak coming from my tank, but it should still be giving the marker enough air to pressurize itself.
Btw, I don't know if "pressurize" is the right term to be using, it just seemed to be the most fit for the problem.
Please help me, guys. I shot this thing one time, but once was enough for me to fall in love with it lol. I would to actually get this working to go out on the field with it.
PostPosted: Sat Mar 19, 2011 10:05 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
Have you adjusted your high pressure reg any?
If you still have the stock high pressure reg you need to find an allen key that matches and turn the hex screw on the bottom clockwise to get more air pressure into the marker.
Yeah, like Nobody said, make sure you're starting around 200 psi on the HPR. (Left side gauge, sighting down the marker)
Forgot to mention that to get the bolt to cock back, you have to screw in the LPR adjuster (with a coin or that plastic disc they give you) clockwise until you're around 90psi. (Right side gauge)
turn the HPR up, till the gauge reads about 200psi. then adjust the LPR to set the bolt. you can also, clean and lube the reg, before putting air on it.
PBpancake
PostPosted: Sat Mar 19, 2011 10:10 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
I adjusted the HPR to where I was chrono'ing at 270-280 at the field last weekend, if that's what you mean. It's not the stock HPR, btw. I have a Dye Hyper 2 regulator on the gun.
And the gauge won't move, so I can't tell what the PSI is. I just realized it isn't the stock gauge, either. It's an Evil, appearently.
PostPosted: Sat Mar 19, 2011 10:38 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
Make sure you are getting air to the HPR as well. sometimes your tank valve pin doesn't get depressed all the way.
PostPosted: Sun Mar 20, 2011 12:17 am    Post subject: Re: My Lasoya ProMaster won't pressurize...
Dumb question (and maybe a little snarky)....is there air in your tank??
So you say when you chronoed last weekend the gauge didn't move at that time either? If that is the case you most definitely have a blown gauge. That won't cause the marker not to work but it will need to be replaced if you want to know the pressure.
Ok, so I completely agree with VDub, sounds like the tank is not screwed in all the way. That or there is no air in there.
Have you adjusted anything on the gun since you removed the tank after the last time you played?
PBpancake
PostPosted: Sun Mar 20, 2011 2:30 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
Yes, I did have air in it lol.
I don't know if the gauge moved or not last weekend, I didn't think to check it. It probably did though since the gun did pressurize and shot just fine during a couple of games.
In the middle of one game it just died while it was still pressurized, it wouldn't let me shoot or anything.
And yes, I'm certain I screwed in my tank on the way, the on/off ASA I have was on too.
PostPosted: Sun Mar 20, 2011 3:24 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
If you are sure the air was turned on properly and your HPR was working and the bolt isn't cocking back then for whatever reason the LPR isn't routing gas through the noid.
Make sure
- your hoses in the grip frame aren't kinked.
- the LPR is assembled properly and lubed.
- you get some new gauges to verify input and output pressures.
Try pressing the red button on the noid while the marker is pressurized.
As far as the maker not functioning at random moments during the game, it could be the disconnect on the harness between the solenoid and battery. I would tape that up to make sure it doesn't disconnect during playtime.
shakenbaker
PostPosted: Sun Mar 20, 2011 7:51 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
i had a similar issue once.. i had a working gun, then nothing.. it was still under pressure, the bolt was back and it seemed ready to fire but wouldnt
come to find out i had reg creep.. when the gun sat for a bit, under pressure it would over pressurize looking at my gauge it was near 400 psi on the hpr side... i cleaned and lubed the hpr and then zeroed the hpr and lpr and started over.. and bang.. works great now.. but i also lube things a bit more often.. just so i dont have it happen again..
Splatmandu.. Key member, Teds Reds,
PBpancake
PostPosted: Sun Mar 20, 2011 9:13 pm    Post subject: Re: My Lasoya ProMaster won't pressurize...
Thanks for all your help guys. I will try pressing the button on the solenoid once I get some more air, probably this weekend.
Stupid question, does it matter how high the PSI on the gauge goes up to? I want to be sure I'll get an accurate reading once the gun is aired up.
